查看: 590|回复: 0
287 289 最新版1.16固件更新
发表于 2013-5-23 09:47:06 | 显示全部楼层 |阅读模式
中文主页上还是1.10版,英文主页上已经有1.16版下载了
http://www.fluke.com/fluke/usen/support/software/DMMUpgrade.htm
1.10更新到1.16过程中忘了截图,这是更新后的截图更新后info可以显示中文
最新的是1.16版本
This upgrade includes these new or expanded capabilities:
  • Corrected an issue where recording sessions could be interrupted or terminated when using the record function in combination with ambient conditions of bright sunlight or other sources of bright light, when used without the IR cable attached.
  • Zoom on trend provide unprecedented ability to view analyz TrendCapture data; see detail at X5 magnification.
  • Rotary switch memory when switching positions between AC or DC A/mA and uA.
  • Adjustable recording and auto hold thresholds, specify a percentage change in the readings that begins a new event.
  • Logging function with expanded memory for unattended monitoring of signals over time. Using on-board TrendCapture users can graphically review logged readings without needing a PC. Store up to 15,000 recorded events.
  • Simplified Record screen when setting up recording.
  • New and improved Trend View graph plot. This new plot algorithm plots the minimum, maximum, and sample point for each sample interval record and event record.
  • Allows 5,000 to 15,000 recorded events for each recording session (events are different than sample intervals).
  • Improves the speed of plotting the trend graph in Trend View.
  • Added fast scrolling through trend data. Useful when viewing trends with large number of events and interval samples.
  • Resolution of plotting on x-axis can now go down to 1/100th of a second.
  • Improved algorithm for generation of Y axis labels.
  • Meter Information screen reports recording memory available.
  • Save Names can be changed using FlukeView Forms.
  • Added Restart softkey in Min/Max and Peak Min/Max.
  • Sticky dB+REL now works for dB+Hz.
  • Shortened time needed to upload recorded data into FlukeView Forms.
  • Settings of Duration and Sample Interval in Recording setup screen is remembered through power off.
  • Last used Saved Name is remember through power off.
  • Updated information appears when the Info button is pressed.
  • Reduced time needed for calibration.
发表于 2013-5-23 10:43:20 | 显示全部楼层
刚刚把289升级了,多谢提醒
发表于 2013-5-23 19:20:35 | 显示全部楼层
开机时间快多了[s:4][s:4]
发表于 2013-5-23 21:17:32 | 显示全部楼层
升级后还有中文吗?
 楼主| 发表于 2013-5-23 21:35:25 | 显示全部楼层
sssaaa 发表于 2013-5-23 21:17
升级后还有中文吗?
看帖不仔细啊
更新后info内可以显示中文
发表于 2013-5-23 23:21:00 | 显示全部楼层
289C刚用串口线升级,没发现什么不一样,开机也不比老版本快。
发表于 2013-5-24 07:29:35 | 显示全部楼层
287 用坛子里的DIY数据线升级了,感觉开机快些了。
发表于 2013-5-24 19:12:47 | 显示全部楼层
多谢楼主,
发表于 2013-5-25 00:05:15 | 显示全部楼层
我289,没有C
