查看: 514|回复: 0
求教---用5520A-6示波器选件,TK3052C频带宽度怎么校准?
发表于 2010-8-1 21:33:52 | 显示全部楼层 |阅读模式
发表于 2010-8-1 22:17:15 | 显示全部楼层
Oscilloscope Connections
Using the cable supplied with the SC1100 Option, connect the SCOPE output on the
Calibrator to one of the channel connectors on your oscilloscope (see Figure 1).
To use the external trigger, connect the TRIG OUT output on the Calibrator to the
external trigger connection on your oscilloscope. To use the external trigger and view its
signal with the calibration signal, connect the TRIG OUT output to another channel. See
your oscilloscope manual for details on connecting and viewing an external trigger.
Starting the SC1100 Option
Press a (LED lit) to select the SC1100 Option. The SCOPE menu, shown below,
appears in the Control Display. You can press any of the first four softkeys to go directly
to the VOLT, EDGE, LEVSINE, and MARKER calibration menus. Press the last softkey
to go to the OTHER menu (also shown below), allowing access to WAVEGEN, VIDEO,
PULSE, Impedance/Capacitance measurement (MEAS Z), and Overload (OVERLD)
menus. Press P to return to the SCOPE menu from the OTHER menu. This manual
describes each of these menus in detail.
Select SCOPE mode:
VOLT EDGE LEVSINE MARKER OTHER
f f f f f
Select SCOPE mode (or PREV MENU):
WAVEGEN VIDEO PULSE MEAS Z OVERLD
f f f f f
 楼主| 发表于 2010-8-1 22:42:20 | 显示全部楼层
我 的选 件是600MHZr的
