查看: 807|回复: 0
求一个5720A自动校准34401A的程序
发表于 2013-2-2 17:51:46 | 显示全部楼层 |阅读模式
有偿求购,最好是232接口的,没有GPIB线,急!
qq272264724
发表于 2013-2-2 20:56:50 | 显示全部楼层
发表于 2013-2-2 20:57:58 | 显示全部楼层
?2001 Fluke Corporation, All rights reserved               MET/CAL Procedure
INSTRUMENT:            HP 34401A: CAL ADJ IEEE /5520
DATE:                  2001-09-27
AUTHOR:                Fluke Corporation
REVISION:              $Revision: 1.3 $
ADJUSTMENT THRESHOLD:  70%
NUMBER OF TESTS:       1
NUMBER OF LINES:       669
CONFIGURATION:         Fluke 5520A
# Source:
#   HP 34401A Multimeter Service Guide (1st edition, November 1991)
#   Consultation with Hewlett-Packard
# Compatibility:
#   MET/CAL 5.0 or later
# Required Files:
#   None
# System Specifications:
#   TUR calculation is based on 5520A 90 day specifications.
# Subprocedures:
#   None
STEP    FSC    RANGE NOMINAL        TOLERANCE     MOD1        MOD2  3  4 CON
  1.001  ASK-                                                              V
  1.002  HEAD         PRELIMINARY INSTRUCTIONS
  1.003  DISP         [32]                   WARNING
  1.003  DISP         HIGH VOLTAGE is used or exposed during the performance
  1.003  DISP         of this calibration. DEATH ON CONTACT may result if
  1.003  DISP         personnel fail to observe safety precautions.
  1.004  DISP         Ambient temperature: 18C - 28C.
  1.004  DISP         Relative humidity: less than 80%.
  1.004  DISP         Warmup time: 2 hour.
  1.005  DISP         Connect the UUT to GPIB port 1.
# Reset UUT, set Std Event bit on error, and get ID string.
  1.006  IEEE         *RST;*CLS;*ESE 60;*IDN?[I$]
# Get primary rev. # out of ID string "HEWLETT-PACKARD,34401A,0,XX-XX-XX"
  1.007  MATH         M[50] = FLD(FLD(MEM2, 4, ","), 1, "-")
  1.008  HEAD         ESTABLISH NEED FOR -10V DC ADJUSTMENT
  1.009  OPBR         Has the A-to-D converter been serviced or the
  1.009  OPBR         calibration RAM (U505) been replaced since
  1.009  OPBR         the last successful calibration adjustment?
  1.010  MATH         M[200] = MEM1
  1.011  HEAD         ESTABLISH NEED FOR 500V DC ADJUSTMENT
# This calibration is available starting with firmware revision 3.
  1.012  MATH         MEM1 = M[50] - 3
  1.013  JMPF         1.017
  1.014  OPBR         Has the divider network (U101) or the
  1.014  OPBR         calibration RAM (U505) been replaced since
  1.014  OPBR         the last successful calibration adjustment?
  1.015  MATH         M[201] = MEM1
  1.016  JMP          1.018
# Firmware revision is not 3 or later.
  1.017  MATH         M[201] = -1
  1.018  HEAD         ESTABLISH NEED FOR 1/100th SCALE AC ADJUSTMENT
# This calibration is available starting with firmware revision 2.
  1.019  MATH         MEM1 = M[50] - 2
  1.020  JMPF         1.024
  1.021  OPBR         Has the AC section been serviced or the
  1.021  OPBR         calibration RAM (U505) been replaced since
  1.021  OPBR         the last successful calibration adjustment?
  1.022  MATH         M[202] = MEM1
  1.023  JMP          1.025
# Firmware revision is not 2 or later.
  1.024  MATH         M[202] = -1
# Unlock CAL Security
  1.025  IEEE         CAL:SEC:STAT OFF,HP034401;*OPC?[I]
  1.026  HEAD         ZERO ADJUSTMENT: Front Panel
  1.027  DISP         Connect a 4-Wire short to the UUT front input terminals.
  1.028  IEEE         ROUT:TERM?[I$]
  1.029  MATH         MEM1 = CMPI(MEM2, "FRON")
  1.030  JMPT         1.033
  1.031  DISP         Place the FRONT/REAR switch in tht FRONT (out) position.
  1.032  JMP          1.028
  1.033  IEEE         CONF:FRES 100,1E-4[D50]READ?[I]
  1.034  MATH         MEM1 = 120
  1.035  HEAD         WAITING 2 MIN. FOR STABILIZATION. [MEM1]s[D1000]
  1.036  MATH         MEM1 = MEM1 - 1
  1.037  JMPT         1.035
  1.038  HEAD         CHECKING FOR THERMAL STABILIZATION
  1.039  MATH         M[1] = MEM
  1.040  IEEE         [D5000]READ?[I]
  1.041  MATH         MEM1 = MEM - M[1]
  1.042  JMPZ         1.044          0.00035U
  1.043  JMP          1.039
  1.044  HEAD         ZERO ADJUSTMENT: Front Panel
  1.045  IEEE         CONF:VOLT:DC;:CAL:VAL 0mV;:CAL?
# Read Status Byte once a second.
  1.046  IEEE         [D1000][SPL]
  1.047  MATH         MEM1 = MEM
  1.048  JMPZ         1.046
# See if bit 5, "Standard Event" was set.  Standard Events were enabled for
# Query Error, Device Error, Execution Error, or Command Error (*ESE 60)
  1.049  MATH         MEM1 = MEM - 32
  1.050  JMPZ         1.518
  1.051  IEEE         [I]
  1.052  MATH         MEM1 = MEM
  1.053  JMPZ         1.055
  1.054  JMP          1.522
  1.055  HEAD         ZERO ADJUSTMENT: Rear Panel
  1.056  DISP         Move the 4-Wire short to the UUT rear input terminals.
  1.057  IEEE         ROUT:TERM?[I$]
  1.058  MATH         MEM1 = CMPI(MEM2, "REAR")
  1.059  JMPT         1.062
  1.060  DISP         Place the FRONT/REAR switch in tht REAR (in) position.
  1.061  JMP          1.057
  1.062  IEEE         CONF:FRES 100,1E-4;*OPC?[I]
  1.063  MATH         MEM1 = 150
  1.064  HEAD         WAITING 2.5 MIN. FOR STABILIZATION. [MEM1]s[D1000]
  1.065  MATH         MEM1 = MEM1 - 1
  1.066  JMPT         1.064
  1.067  HEAD         CHECKING FOR THERMAL STABILIZATION
  1.068  MATH         M[1] = MEM
  1.069  IEEE         [D5000]READ?[I]
  1.070  MATH         MEM1 = MEM - M[1]
  1.071  JMPZ         1.073          0.00035U
  1.072  JMP          1.068
  1.073  HEAD         ZERO ADJUSTMENT: Rear Panel
  1.074  IEEE         CONF:VOLT:DC;:CAL:VAL 0mV;:CAL?
  1.075  IEEE         [D1000][SPL]
  1.076  MATH         MEM1 = MEM
  1.077  JMPZ         1.075
  1.078  MATH         MEM1 = MEM - 32
  1.079  JMPZ         1.518
  1.080  IEEE         [I]
  1.081  MATH         MEM1 = MEM
  1.082  JMPZ         1.084
  1.083  JMP          1.522
  1.084  HEAD         DC VOLTAGE: 100mV Range
  1.085  IEEE         ROUT:TERM?[I$]
  1.086  MATH         MEM1 = CMPI(MEM2, "FRON")
  1.087  JMPT         1.090
  1.088  DISP         Remove the short from the rear input terminals.
  1.088  DISP
  1.088  DISP         Place the FRONT/REAR switch in tht FRONT (out) position.
  1.089  JMP          1.085
  1.090  DISP         Connect the 5520A to the UUT as follows:
  1.090  DISP         [32] 5520A NORMAL HI to UUT FRONT INPUT HI
  1.090  DISP         [32] 5520A NORMAL LO to UUT FRONT INPUT LO
  1.091  IEEE         CONF:VOLT:DC 100mV,MIN;*OPC?[I]
  1.092  5520         100mV                                             S  2W
  1.093  IEEE         CAL:VAL 100mV;:CAL?
  1.094  IEEE         [D1000][SPL]
  1.095  MATH         MEM1 = MEM
  1.096  JMPZ         1.094
  1.097  MATH         MEM1 = MEM - 32
  1.098  JMPZ         1.518
  1.099  IEEE         [I]
  1.100  MATH         MEM1 = MEM
  1.101  JMPZ         1.103
  1.102  JMP          1.522
  1.103  HEAD         DC VOLTAGE: 1V Range
  1.104  IEEE         CONF:VOLT:DC 1V,MIN;*OPC?[I]
  1.105  5520         1V                                                S  2W
  1.106  IEEE         CAL:VAL 1V;:CAL?
  1.107  IEEE         [D1000][SPL]
  1.108  MATH         MEM1 = MEM
  1.109  JMPZ         1.107
  1.110  MATH         MEM1 = MEM - 32
  1.111  JMPZ         1.518
  1.112  IEEE         [I]
  1.113  MATH         MEM1 = MEM
  1.114  JMPZ         1.116
  1.115  JMP          1.522
  1.116  HEAD         DC VOLTAGE: 10V Range
  1.117  IEEE         CONF:VOLT:DC 10V,MIN;*OPC?[I]
  1.118  5520         10V                                               S  2W
  1.119  IEEE         CAL:VAL 10V;:CAL?
  1.120  IEEE         [D1000][SPL]
  1.121  MATH         MEM1 = MEM
  1.122  JMPZ         1.120
  1.123  MATH         MEM1 = MEM - 32
  1.124  JMPZ         1.518
  1.125  IEEE         [I]
  1.126  MATH         MEM1 = MEM
  1.127  JMPZ         1.129
  1.128  JMP          1.522
  1.129  MATH         MEM1 = M[200]
  1.130  JMPF         1.152
# These adjustments should be performed following repair of your multimeter.
# You are not required to perform these adjustments at any other interval.
  1.131  IEEE         VOLT:DC:NPLC 100;*OPC?[I]
  1.132  5520         10V                                               S  2W
# Obtain and store +10V calibration reading.
  1.133  IEEE         READ?[I]
  1.134  MATH         M[20] = MEM
  1.135  5520         -10V                                              S  2W
# Enter the +10V reading with the "-" sign for the -10V calibration value.
  1.136  MATH         MEM = -1 * M[20]
  1.137  IEEE         CAL:VAL [MEM]V;:CAL?
  1.138  IEEE         [D1000][SPL]
  1.139  MATH         MEM1 = MEM
  1.140  JMPZ         1.138
  1.141  MATH         MEM1 = MEM - 32
  1.142  JMPZ         1.518
  1.143  IEEE         [I]
  1.144  MATH         MEM1 = MEM
  1.145  JMPZ         1.147
  1.146  JMP          1.522
# Verify that the -10V reading is within 30uV of the +10V reading.
  1.147  IEEE         READ?[I]
  1.148  MATH         MEM1 = M[20] + MEM
  1.149  JMPZ         1.152          3e-005U
  1.150  DISP         -10V reading is not within 30uV of the +10V reading.
  1.151  JMP          1.523
  1.152  HEAD         DC VOLTAGE: 100V Range
  1.153  IEEE         CONF:VOLT:DC 100V,MIN;:VOLT:DC:NPLC 10;*OPC?[I]
  1.154  5520         100V                                              S  2W
  1.155  IEEE         CAL:VAL 100V;:CAL?
  1.156  IEEE         [D1000][SPL]
  1.157  MATH         MEM1 = MEM
  1.158  JMPZ         1.156
  1.159  MATH         MEM1 = MEM - 32
  1.160  JMPZ         1.518
  1.161  IEEE         [I]
  1.162  MATH         MEM1 = MEM
  1.163  JMPZ         1.165
  1.164  JMP          1.522
  1.165  HEAD         DC VOLTAGE: 1000V Range
  1.166  IEEE         CONF:VOLT:DC 1000V,MIN;*OPC?[I]
  1.167  5520         1000V                                             S  2W
  1.168  IEEE         CAL:VAL 1000V;:CAL?
  1.169  IEEE         [D1000][SPL]
  1.170  MATH         MEM1 = MEM
  1.171  JMPZ         1.169
  1.172  MATH         MEM1 = MEM - 32
  1.173  JMPZ         1.518
  1.174  IEEE         [I]
  1.175  MATH         MEM1 = MEM
  1.176  JMPZ         1.178
  1.177  JMP          1.522
  1.178  5520         *                                                 S
  1.179  MATH         MEM1 = M[201]
  1.180  JMPF         1.188
# This adjustment should be performed only after replacement of the divider
# network U101 of the calibration RAM U505.
  1.181  HEAD         100:1 DIVIDER NETWORK
  1.182  5520         500V                                              S  2W
  1.183  IEEE         READ?[I]
  1.184  5520         *                                                 S
  1.185  MATH         MEM1 = 500 - MEM
# Check for a 82% marginal pass or failure.
  1.186  JMPZ         1.188          0.00492U
  1.187  DISP         UUT reading is not within 82% of spec.
  1.187  DISP
  1.187  DISP         Upon completion of this procedure you must perform the
  1.187  DISP         "500 Vdc Adjustment Procedure" outlined in the section
  1.187  DISP         "Optional Gain Calibration Procedures" of Chapter 4 in
  1.187  DISP         the 34401A Service Guide.
  1.188  HEAD         4-WIRE RESISTANCE: 100 Ohm Range
  1.189  DISP         Connect the 5520A to the UUT as follows:
  1.189  DISP         [32] 5520A NORMAL HI to UUT FRONT INPUT HI
  1.189  DISP         [32] 5520A NORMAL LO to UUT FRONT INPUT LO
  1.189  DISP         [32] 5520A AUX HI to UUT FRONT SENSE HI
  1.189  DISP         [32] 5520A AUX LO to UUT FRONT SENSE LO
  1.190  IEEE         CONF:FRES 100 Ohm,MIN;*OPC?[I]
  1.191  5520         100Z                                              S  4W
  1.192  IEEE         CAL:VAL [MEM1]Ohm;:CAL?
  1.193  IEEE         [D1000][SPL]
  1.194  MATH         MEM1 = MEM
  1.195  JMPZ         1.193
  1.196  MATH         MEM1 = MEM - 32
  1.197  JMPZ         1.518
  1.198  IEEE         [I]
  1.199  MATH         MEM1 = MEM
  1.200  JMPZ         1.202
  1.201  JMP          1.522
  1.202  HEAD         4-WIRE RESISTANCE: 1 kOhm Range
  1.203  IEEE         CONF:FRES 1 kOhm,MIN;*OPC?[I]
  1.204  5520         1kZ                                               S  4W
  1.205  IEEE         CAL:VAL [MEM1]kOhm;:CAL?
  1.206  IEEE         [D1000][SPL]
  1.207  MATH         MEM1 = MEM
  1.208  JMPZ         1.206
  1.209  MATH         MEM1 = MEM - 32
  1.210  JMPZ         1.518
  1.211  IEEE         [I]
  1.212  MATH         MEM1 = MEM
  1.213  JMPZ         1.215
  1.214  JMP          1.522
  1.215  HEAD         4-WIRE RESISTANCE: 10 kOhm Range
  1.216  IEEE         CONF:FRES 10 kOhm,MIN;*OPC?[I]
  1.217  5520         10kZ                                              S  4W
  1.218  IEEE         CAL:VAL [MEM1]kOhm;:CAL?
  1.219  IEEE         [D1000][SPL]
  1.220  MATH         MEM1 = MEM
  1.221  JMPZ         1.219
  1.222  MATH         MEM1 = MEM - 32
  1.223  JMPZ         1.518
  1.224  IEEE         [I]
  1.225  MATH         MEM1 = MEM
  1.226  JMPZ         1.228
  1.227  JMP          1.522
  1.228  HEAD         4-WIRE RESISTANCE: 100 kOhm Range
  1.229  IEEE         CONF:FRES 100 kOhm,MIN;*OPC?[I]
  1.230  5520         100kZ                                             S  4W
  1.231  IEEE         CAL:VAL [MEM1]kOhm;:CAL?
  1.232  IEEE         [D1000][SPL]
  1.233  MATH         MEM1 = MEM
  1.234  JMPZ         1.232
  1.235  MATH         MEM1 = MEM - 32
  1.236  JMPZ         1.518
  1.237  IEEE         [I]
  1.238  MATH         MEM1 = MEM
  1.239  JMPZ         1.241
  1.240  JMP          1.522
  1.241  5520         *                                                 S
  1.242  HEAD         4-WIRE RESISTANCE: 1 MOhm Range
  1.243  DISP         Connect the 5520A to the UUT as follows:
  1.243  DISP         [32] 5520A NORMAL HI to UUT FRONT SENSE HI
  1.243  DISP         [32] 5520A NORMAL LO to UUT FRONT SENSE LO
  1.243  DISP         [32] 5520A NORMAL HI to UUT FRONT INPUT HI
  1.243  DISP         [32] 5520A NORMAL LO to UUT FRONT INPUT LO
  1.244  IEEE         CONF:FRES 1 MOhm,MIN;*OPC?[I]
  1.245  5520         1MZ                                               S  2W
  1.246  IEEE         CAL:VAL [MEM1]MOhm[D5000]CAL?
  1.247  IEEE         [D1000][SPL]
  1.248  MATH         MEM1 = MEM
  1.249  JMPZ         1.247
  1.250  MATH         MEM1 = MEM - 32
  1.251  JMPZ         1.518
  1.252  IEEE         [I]
  1.253  MATH         MEM1 = MEM
  1.254  JMPZ         1.256
  1.255  JMP          1.522
  1.256  HEAD         4-WIRE RESISTANCE: 10 MOhm Range
  1.257  IEEE         CONF:FRES 10 MOhm,MIN;*OPC?[I]
  1.258  5520         10MZ                                              S  2W
  1.259  IEEE         CAL:VAL [MEM1]MOhm[D10000]CAL?
  1.260  IEEE         [D1000][SPL]
  1.261  MATH         MEM1 = MEM
  1.262  JMPZ         1.260
  1.263  MATH         MEM1 = MEM - 32
  1.264  JMPZ         1.518
  1.265  IEEE         [I]
  1.266  MATH         MEM1 = MEM
  1.267  JMPZ         1.269
  1.268  JMP          1.522
  1.269  5520         *                                                 S
  1.270  HEAD         DC CURRENT: 10mA Range
  1.271  DISP         Connect the 5520A to the UUT as follows:
  1.271  DISP         [32] 5520A AUX HI to UUT FRONT 3A INPUT
  1.271  DISP         [32] 5520A AUX LO to UUT FRONT INPUT LO
  1.272  IEEE         CONF:CURR:DC 10mA,MIN;*OPC?[I]
  1.273  5520         10mA                                              S  2W
  1.274  IEEE         CAL:VAL 0.010;:CAL?
  1.275  IEEE         [D1000][SPL]
  1.276  MATH         MEM1 = MEM
  1.277  JMPZ         1.275
  1.278  MATH         MEM1 = MEM - 32
  1.279  JMPZ         1.518
  1.280  IEEE         [I]
  1.281  MATH         MEM1 = MEM
  1.282  JMPZ         1.284
  1.283  JMP          1.522
  1.284  HEAD         DC CURRENT: 100mA Range
  1.285  IEEE         CONF:CURR:DC 100mA,MIN;*OPC?[I]
  1.286  5520         100mA                                             S  2W
  1.287  IEEE         CAL:VAL 0.100;:CAL?
  1.288  IEEE         [D1000][SPL]
  1.289  MATH         MEM1 = MEM
  1.290  JMPZ         1.288
  1.291  MATH         MEM1 = MEM - 32
  1.292  JMPZ         1.518
  1.293  IEEE         [I]
  1.294  MATH         MEM1 = MEM
  1.295  JMPZ         1.297
  1.296  JMP          1.522
  1.297  HEAD         DC CURRENT: 1A Range
  1.298  IEEE         CONF:CURR:DC 1A,MIN;*OPC?[I]
  1.299  5520         1A                                                S  2W
  1.300  IEEE         CAL:VAL 1;:CAL?
  1.301  IEEE         [D1000][SPL]
  1.302  MATH         MEM1 = MEM
  1.303  JMPZ         1.301
  1.304  MATH         MEM1 = MEM - 32
  1.305  JMPZ         1.518
  1.306  IEEE         [I]
  1.307  MATH         MEM1 = MEM
  1.308  JMPZ         1.310
  1.309  JMP          1.522
  1.310  HEAD         DC CURRENT: 3A Range
  1.311  IEEE         CONF:CURR:DC 3A,MIN;*OPC?[I]
  1.312  5520         2A                                                S  2W
  1.313  IEEE         CAL:VAL 2;:CAL?
  1.314  IEEE         [D1000][SPL]
  1.315  MATH         MEM1 = MEM
  1.316  JMPZ         1.314
  1.317  MATH         MEM1 = MEM - 32
  1.318  JMPZ         1.518
  1.319  IEEE         [I]
  1.320  MATH         MEM1 = MEM
  1.321  JMPZ         1.323
  1.322  JMP          1.522
  1.323  5520         *                                                 S
  1.324  HEAD         AC VOLTAGE: 100mV Range
  1.325  DISP         Connect the 5520A to the UUT as follows:
  1.325  DISP         [32] 5520A NORMAL HI to UUT FRONT INPUT HI
  1.325  DISP         [32] 5520A NORMAL LO to UUT FRONT INPUT LO
  1.326  IEEE         CONF:VOLT:AC 100mV,MIN;*OPC?[I]
  1.327  5520         100mV                        1kH            SI    S  2W
  1.328  IEEE         CAL:VAL 100mV;:CAL?
  1.329  IEEE         [D1000][SPL]
  1.330  MATH         MEM1 = MEM
  1.331  JMPZ         1.329
  1.332  MATH         MEM1 = MEM - 32
  1.333  JMPZ         1.518
  1.334  IEEE         [I]
  1.335  MATH         MEM1 = MEM
  1.336  JMPZ         1.338
  1.337  JMP          1.522
  1.338  5520         100mV                        50kH           SI    S  2W
  1.339  IEEE         CAL:VAL 100mV;:CAL?
  1.340  IEEE         [D1000][SPL]
  1.341  MATH         MEM1 = MEM
  1.342  JMPZ         1.340
  1.343  MATH         MEM1 = MEM - 32
  1.344  JMPZ         1.518
  1.345  IEEE         [I]
  1.346  MATH         MEM1 = MEM
  1.347  JMPZ         1.349
  1.348  JMP          1.522
  1.349  HEAD         AC VOLTAGE: 1V Range
  1.350  IEEE         CONF:VOLT:AC 1V,MIN;*OPC?[I]
  1.351  5520         1V                           1kH            SI    S  2W
  1.352  IEEE         CAL:VAL 1V;:CAL?
  1.353  IEEE         [D1000][SPL]
  1.354  MATH         MEM1 = MEM
  1.355  JMPZ         1.353
  1.356  MATH         MEM1 = MEM - 32
  1.357  JMPZ         1.518
  1.358  IEEE         [I]
  1.359  MATH         MEM1 = MEM
  1.360  JMPZ         1.362
  1.361  JMP          1.522
  1.362  5520         1V                           50kH           SI    S  2W
  1.363  IEEE         CAL:VAL 1V;:CAL?
  1.364  IEEE         [D1000][SPL]
  1.365  MATH         MEM1 = MEM
  1.366  JMPZ         1.364
  1.367  MATH         MEM1 = MEM - 32
  1.368  JMPZ         1.518
  1.369  IEEE         [I]
  1.370  MATH         MEM1 = MEM
  1.371  JMPZ         1.373
  1.372  JMP          1.522
  1.373  HEAD         AC VOLTAGE: 10V Range
  1.374  IEEE         CONF:VOLT:AC 10V,MIN;*OPC?[I]
  1.375  5520         10V                          1kH            SI    S  2W
  1.376  IEEE         CAL:VAL 10V;:CAL?
  1.377  IEEE         [D1000][SPL]
  1.378  MATH         MEM1 = MEM
  1.379  JMPZ         1.377
  1.380  MATH         MEM1 = MEM - 32
  1.381  JMPZ         1.518
  1.382  IEEE         [I]
  1.383  MATH         MEM1 = MEM
  1.384  JMPZ         1.386
  1.385  JMP          1.522
  1.386  5520         10V                          50kH           SI    S  2W
  1.387  IEEE         CAL:VAL 10V;:CAL?
  1.388  IEEE         [D1000][SPL]
  1.389  MATH         MEM1 = MEM
  1.390  JMPZ         1.388
  1.391  MATH         MEM1 = MEM - 32
  1.392  JMPZ         1.518
  1.393  IEEE         [I]
  1.394  MATH         MEM1 = MEM
  1.395  JMPZ         1.397
  1.396  JMP          1.522
  1.397  IEEE         DET:BAND 3;*OPC?[I]
  1.398  5520         10V                          10H            SI    S  2W
  1.399  IEEE         CAL:VAL 10;:CAL?
  1.400  IEEE         [D1000][SPL]
  1.401  MATH         MEM1 = MEM
  1.402  JMPZ         1.400
  1.403  MATH         MEM1 = MEM - 32
  1.404  JMPZ         1.518
  1.405  IEEE         [I]
  1.406  MATH         MEM1 = MEM
  1.407  JMPZ         1.409
  1.408  JMP          1.522
  1.409  HEAD         AC VOLTAGE: 100mV Range
  1.410  IEEE         CONF:VOLT:AC 100mV,MIN;*OPC?[I]
  1.411  5520         10mV                         1kH            SI    S  2W
  1.412  IEEE         CAL:VAL 10mV;:CAL?
  1.413  IEEE         [D1000][SPL]
  1.414  MATH         MEM1 = MEM
  1.415  JMPZ         1.413
  1.416  MATH         MEM1 = MEM - 32
  1.417  JMPZ         1.518
  1.418  IEEE         [I]
  1.419  MATH         MEM1 = MEM
  1.420  JMPZ         1.422
  1.421  JMP          1.522
  1.422  HEAD         AC VOLTAGE: 100V Range
  1.423  IEEE         CONF:VOLT:AC 100V,MIN;*OPC?[I]
  1.424  5520         100V                         1kH            SI    S  2W
  1.425  IEEE         CAL:VAL 100V;:CAL?
  1.426  IEEE         [D1000][SPL]
  1.427  MATH         MEM1 = MEM
  1.428  JMPZ         1.426
  1.429  MATH         MEM1 = MEM - 32
  1.430  JMPZ         1.518
  1.431  IEEE         [I]
  1.432  MATH         MEM1 = MEM
  1.433  JMPZ         1.435
  1.434  JMP          1.522
  1.435  HEAD         AC VOLTAGE: 100V Range
  1.436  IEEE         CONF:VOLT:AC 100V,MIN;*OPC?[I]
  1.437  5520         100V                         50kH           SI    S  2W
  1.438  IEEE         CAL:VAL 100V;:CAL?
  1.439  IEEE         [D1000][SPL]
  1.440  MATH         MEM1 = MEM
  1.441  JMPZ         1.439
  1.442  MATH         MEM1 = MEM - 32
  1.443  JMPZ         1.518
  1.444  IEEE         [I]
  1.445  MATH         MEM1 = MEM
  1.446  JMPZ         1.448
  1.447  JMP          1.522
  1.448  HEAD         AC VOLTAGE: 750V Range
  1.449  IEEE         CONF:VOLT:AC 750V,MIN;*OPC?[I]
  1.450  5520         700V                         1kH            SI    S  2W
  1.451  IEEE         CAL:VAL 700V;:CAL?
  1.452  IEEE         [D1000][SPL]
  1.453  MATH         MEM1 = MEM
  1.454  JMPZ         1.452
  1.455  MATH         MEM1 = MEM - 32
  1.456  JMPZ         1.518
  1.457  IEEE         [I]
  1.458  MATH         MEM1 = MEM
  1.459  JMPZ         1.461
  1.460  JMP          1.522
  1.461  HEAD         AC VOLTAGE: 750V Range
  1.462  IEEE         CONF:VOLT:AC 750V,MIN;*OPC?[I]
  1.463  5520         250V                         50kH           SI    S  2W
  1.464  IEEE         CAL:VAL 250V;:CAL?
  1.465  IEEE         [D1000][SPL]
  1.466  MATH         MEM1 = MEM
  1.467  JMPZ         1.465
  1.468  MATH         MEM1 = MEM - 32
  1.469  JMPZ         1.518
  1.470  IEEE         [I]
  1.471  MATH         MEM1 = MEM
  1.472  JMPZ         1.474
  1.473  JMP          1.522
  1.474  5520         *                                                 S
# This adjustment should be preformed after servicing AC section circuits of
# after replacement of the calibration RAM U505.
  1.475  MATH         MEM1 = M[202]
  1.476  JMPF         1.495
  1.477  HEAD         1/100th SCALE AC ADJUSTMENT
  1.478  IEEE         CONF:CURR:AC 1A,MIN;*OPC?[I]
  1.479  5520         0.0100A                      1kH            SI    S  2W
  1.480  IEEE         CAL:VAL 0.01;:CAL?
  1.481  IEEE         [D1000][SPL]
  1.482  MATH         MEM1 = MEM
  1.483  JMPZ         1.481
  1.484  MATH         MEM1 = MEM - 32
  1.485  JMPZ         1.518
  1.486  IEEE         [I]
  1.487  MATH         MEM1 = MEM
  1.488  JMPZ         1.490
  1.489  JMP          1.522
  1.490  IEEE         READ?[I]
  1.491  MATH         MEM1 = 0.01 - MEM
  1.492  JMPZ         1.495          0.0004U
  1.493  DISP         UUT reading is not 10mA +/-400uA.
  1.494  JMP          1.523
  1.495  5520         *                                                 S
  1.496  HEAD         FREQUENCY
  1.497  IEEE         CONF:FREQ 100kHz,0.1Hz;*OPC?[I]
  1.498  5520         100kH                        1V             SI    S  2W
  1.499  IEEE         CAL:VAL 100kHz;:CAL?
  1.500  IEEE         [D1000][SPL]
  1.501  MATH         MEM1 = MEM
  1.502  JMPZ         1.500
  1.503  MATH         MEM1 = MEM - 32
  1.504  JMPZ         1.518
  1.505  IEEE         [I]
  1.506  MATH         MEM1 = MEM
  1.507  JMPZ         1.509
  1.508  JMP          1.522
  1.509  5520         *                                                 S
  1.510  HEAD
# Re-secure CAL security code.
  1.511  IEEE         CAL:SEC:STAT ON
  1.512  JMPZ         1.525
  1.513  DISP         ERROR: Error - Flatness Error too Great! Exit program!
  1.514  JMP          1.519
  1.515  MATH         MEM1 = M[1]
  1.516  DISP         ERROR: Calculated dac value [MEM1] out of range!
  1.517  JMP          1.523
  1.518  IEEE         SYST:ERR?[I$]
  1.519  DISP         UUT Error: [MEM2]
  1.520  IEEE         *CLS
  1.521  JMP          1.523
  1.522  DISP         Cal. adjustment error reported by UUT.
  1.523  DISP         P R O C E D U R E   A B O R T E D !
  1.524  JMP          1.527
  1.525  HEAD
  1.526  DISP         A D J U S T M E N T   C O M P L E T E
  1.527  END
发表于 2013-2-3 16:22:43 | 显示全部楼层
助人为乐
发表于 2013-2-4 01:15:41 | 显示全部楼层
回 wbxms 的帖子
wbxms:?2001 Fluke Corporation, All rights reserved               MET/CAL Procedure
INSTRUMENT:     .. (2013-02-02  20:57)
感谢分享啊。
 楼主| 发表于 2013-2-13 15:22:57 | 显示全部楼层
是不是我没有说清楚,我要的是计量校准实验室用的计量校准程序,烦请大侠赐教。
 楼主| 发表于 2013-3-16 07:34:55 | 显示全部楼层
大大们,给力啊
发表于 2013-3-27 15:45:14 | 显示全部楼层
应该是,HP 34401A: CAL VER IEEE /5520。
匿名用户  发表于 2013-5-2 16:01:08
我们公司开发了 一套5720校准6 1/2万用表的程序  可以校准34401 3420 34410 34970 8845 8846 等很多型号 功能强大 并且实用。 可以与我联系 13510805398
