查看: 866|回复: 0
100KHZ 以上的 LCR 电桥要如何实现呢?
发表于 2012-10-25 16:58:56 | 显示全部楼层 |阅读模式
以下的截图出自 HP 的阻抗量测手册 2-7 页。
上图是一般手持式的 LCR 表改采用的自动平衡电挢结构,量测频率最高到 100KHZ,网路上流传的 DIY LCR 电挢都是此种原理。
下图是量测频率 100KHZ 以上的结构图,相信桌上型的 LCR 电挢是这样做,所以电路看起来才会那么庞大。
不知道上图的自动平衡为何频率限制在 100KHZ 以下?我在实做时也发现这样的情形,只要一高过 100KHZ 量测结果就不准。
下图看起来是加了很多校正电路,到底高频率的 LCR 电挢为什么那么难做?也很难找到参考资料,大家可以讨论一下吗?谢谢。
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有账号?立即注册
x
发表于 2012-10-25 18:10:31 | 显示全部楼层
同问。。。。。。。。
发表于 2012-10-26 00:19:46 | 显示全部楼层
这个要关注啊!
发表于 2012-10-26 11:37:46 | 显示全部楼层
听高手讲课
发表于 2012-10-26 13:29:44 | 显示全部楼层
频率高了,运放的相移严重,大概是这个原因吧。
 楼主| 发表于 2012-10-26 17:02:58 | 显示全部楼层
大家好,手册上这一段说明 100 kHz 结构的原理,一直看不懂他在说什麼,
能否帮我研究看看,文章有点长,小弟在此谢过。
Low frequency instruments, below 100 kHz, employ a simple operational amplifier to configure the
null detector and the equivalent of OSC2 as shown in Figure 2-5 (b). This circuit configuration
cannot be used at frequencies higher than 100 kHz because of the performance limits of the operational
amplifier. The instruments that cover frequencies above 100 kHz have an auto balancing
bridge circuit consisting of a null detector, 0°/90° phase detectors, and a vector modulator as shown
in Figure 2-5 (c). When an unbalance current is detected with the null detector, the phase detectors
in the next stage separate the current into 0° and 90° vector components. The phase detector output
signals go through loop filters (integrators) and are applied to the vector modulator to drive the
0°/90° component signals. The 0°/90° component signals are compounded and the resultant
signal is fed back through range resistor (Rr) to cancel the current flowing through the DUT. Even if
the balancing control loop has phase errors, the unbalance current component, due to the phase
errors, is also detected and fed back to cancel the error in the range resistor current. Consequently,
the unbalance current converges to exactly zero, ensuring Ix = Ir over a broad frequency range up to
110 MHz.
发表于 2012-10-27 00:04:41 | 显示全部楼层
意思就是Rr在100hkz以上时不能认为是纯电阻了 要通过0/90度测出的误差反相合成一个矢量来抵消Rr的电容电感成分 这就是自动调零
发表于 2012-10-27 00:14:28 | 显示全部楼层
而且这是没有希望的发展方向
所以才解密了 网上也能下到了 6,70年代的确是高技术
因为是模拟技术
不管温度漂移还是电压工作点、
理论上这个抵消是不可能到0 只是无限接近于0
到了110mhz左右 连这个反向合成的矢量都会受到传输线路影响 到作用点时候都不准了
现代网络分析仪都是在中频上采集ADC 然后直接通过数据计算出幅度和相位 多次测量后平均消除误差
6端口反射计更加一步到位 每个频率点直接算出9个校正参数 只要有本振和电压表就能用标量测量矢量了
发表于 2012-10-27 00:27:39 | 显示全部楼层
100khz以上的自动调零其实和锁相环一样
锁相环就是锁定的时候 也是有一个固定的最小系统残差相位 不可能和参考相位完全一模一样
这个自动调零就是调到零的时候 也有个最小固定系统误差 不是真正的0
大家比水平 就是比能控制的最小误差能小和稳定到啥程度
大公司一般来说这个最小误差就能搞的稳定的多 这个也是自动控制理论的极限了 更上一层的就是数字信号处理了
发表于 2012-10-27 00:34:57 | 显示全部楼层
我咋弄的和在说内功心法一样
自己都晕
