查看: 607|回复: 0
安捷伦10073C 10073C 无源探头,10:1,500 MHz,1.5 米
发表于 2012-4-1 15:24:03 | 显示全部楼层 |阅读模式
主要特性与技术指标   成色新 现货100条   400元/条
    [li]Bandwidth: 500 MHz[/li][li]System risetime (calculated): <700 ps[/li][li]Attenuation Ratio: 10:1[/li][li]Input resistance: 2.2 MΩ (when terminated into 1 MOhm)[/li]
描述
The Agilent 10073C passive probe is our most rugged 500 MHz probe. With a 10:1 attenuation ratio and high 2.2 M ohm input impedance, it is ideal as a general purpose, high bandwidth passive probe for the Agilent 300 MHz - 1 GHz 6000 series, 7000, 8000 and 9000 Series oscilloscopes. The probe identification feature automatically configures the oscilloscope for the probe attenuation.
The following accessories are included: retractable hook tip; orange, white, blue and green identification tags; ground bayonet, IC probing tip, adjustment tool and an alligator clip ground lead.
    [li]Bandwidth: 500 MHz[/li][li]System risetime (calculated): <700 ps[/li][li]Attenuation Ratio: 10:1[/li][li]Input resistance: 2.2 MΩ (when terminated into 1 MOhm)[/li][li]Input capacitance: ~12 pF[/li][li]Maximum input (dc + peak ac): 500 V CAT I (mains isolated) 300 V CAT II (post receptacle mains)[/li][li]Compensation range: 6 - 15 pF[/li]
 楼主| 发表于 2012-4-1 15:41:59 | 显示全部楼层
发表于 2012-4-1 16:02:49 | 显示全部楼层
好东西买不起。。。。。。。。
100能接受,呵呵
发表于 2012-4-1 16:20:56 | 显示全部楼层
好探头,,
头次见卖这探头的连安捷伦的牌子都不打的,,呵呵,,
