查看: 752|回复: 0
HP部件编号对通用部件编号的列表(带换部件列表)
发表于 2012-3-26 00:22:08 | 显示全部楼层 |阅读模式
PC键盘Ctrl+F组合键自己寻找需要的部件了喔!
E文好的XD原帖见:http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv010.cgi?read=27258
为方便大家寻找部件带换,我举个例子:1810,0076=1810-0076 , 部件号
1810后面的标点符号“,”等于HP部件号标注的“-”,所以
1810,0076=1810-0076
1810,0076,后的部件编号
SIL Resistor 1k8*8即为带换部件号!
。。。。。。。。。。。。。。。。。。。美丽的分化线。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
1810,0076,SIL Resistor 1k8*8,,
1810,0081,Resistor Pack,"""Multi-Value 27110 HPIB""",
1810,0122,Resistor Pack,3k3*13,
1810,0190,Resistor Pack,2k2*13,
1810,0206,Resistor Pack,10k SIP,
1810,0235,Resistor Pack,2k2 * 15,
1810,0307,AB316-101,100 Ohm resistor pack,
1810,0485,Resistor Pack,22k * 7 DIP,
1810,0592,RC Network,HPIL termination,
1810,0651,Network,HPIL components,
1810,0719,Resistor Pack,1k5 * 15,
1813,0285,20MHz osc,,
1813,0327,Delay Line,"""35ns 75ns HP150 RAM card""",
1813,0453,35.19MHz osc,,
1816,1104,no id number,1K ROM HP1350 Char. Gen.,
1816,1105,no id number,1K ROM HP1350 Char. Gen.,
1816,1118,no id number,256K ROM HP1350 Char. Gen.,
1816,1119,no id number,256K ROM HP1350 Char. Gen.,
1816,1120,82S126,Preprogrammed for HP1350 I/O,
1816,1697,63S241,PROM - HP150 Expanded RAM card,
1816,0353,74S188N,STTL,
1816,0354,74S387N,STTL,
1818,1003,C71016,9825B ROM - 00K LSB,
1818,1004,C51039,9825B ROM - 00K MSB,
1818,1267,C71019,9825B ROM - 10K LSB,
1818,1268,C51268,9825B ROM - 10K MSB,
1818,1269,C71021,9825B ROM - 20K LSB,
1818,1270,C51288,9825B ROM - 20K MSB,
1818,1271,C71023,9825B ROM - OPTA LSB,
1818,1272,C71024,9825B ROM - OPTA MSB,
1818,1273,C71025,9825B ROM - OPTB LSB,
1818,1274,C51292,9825B ROM - OPTB MSB,
1818,1275,CN45010,,
1818,1437,uPD446C-2,Memory,
1818,1611,6116,2K*8 RAM,
1818,1754,uPD5101,1K*4 CMOS SRAM,
1818,1774,2114,1K*4 RAM,
1818,1817,MK36844,ROM - HP9836,
1818,1818,MK36844,ROM - HP9836,
1818,3059,4164,DRAM,
1818,3079,2364,"""8k*8 ROM 3421 DAQ unit""",
1818,3080,2364,"""8k*8 ROM 3421 DAQ unit""",
1818,3198,6264,8K*8 RAM,
1818,3447,27128,EPROM,
1818,3526,AM9233CPC,IC,
1818,3529,23256,HP150-II ROM 1,
1818,3530,23256,HP150-II ROM 2,
1818,3531,23256,HP150-II ROM 3,
1818,3604,27128,EPROM,
1818,3648,23256,HP150-II ROM 0,
1818,3649,23256,HP150-II ROM 4,
1818,3932,62256,32K * 8 SRAM,
1818,4372,27128,EPROM,
1818,4373,27128,EPROM,
1818,4486,27C010-155,EPROM,
1818,0156,,4K DRAM,
1818,0373,MK34127N,,
1818,0643,6514?,1K*4 CMOS RAM,
1818,0701,6810,"""128 x 8 RAM",
1820,1032,74198,,
1820,1050,75454,,
1820,1053,7414,,
1820,1056,74132,,
1820,1057,DM86L76N,,
1820,1072,74S139,,
1820,1074,74128,,
1820,1076,74S174,,
1820,1077,74S157,,
1820,1112,74LS74N,,
1820,1114,mc14510bcp ,bcd up/down counter cmos,
1820,1120,uhp-402 sprag,"""ue """"general interface buffer"""" (HP special)""",
1820,1144,74LS02N,,
1820,1146,4050,,
1820,1150,4518,,
1820,1166,DM85L51N,,
1820,1193,74LS197,,
1820,1194,74LS193,,
1820,1195,74LS175N,,
1820,1196,74LS174,,
1820,1197,74LS00N,,
1820,1198,74LS03,,
1820,1199,74LS04N,,
1820,1200,74LS05,,
1820,1201,74LS08N,,
1820,1202,74LS10,,
1820,1203,74LS11,,
1820,1204,74LS20,,
1820,1205,74LS21,,
1820,1206,74LS27,,
1820,1207,74LS30N,,
1820,1208,SN74LS32N,LSTTL IC,
1820,1210,74LS51,,
1820,1211,SN74LS86AN,LSTTL IC,
1820,1212,74LS112,,
1820,1216,SN74LS138N,LSTTL IC,
1820,1217,74LS151,,
1820,1238,74LS253,,
1820,1240,74S138,,
1820,1244,74LS153,,
1820,1245,74LS155,,
1820,1255,DM8096N,* Interface IC similair to 74366,
1820,1257,74159,,
1820,1258,74178,,
1820,1260,74LS221,,
1820,1275,74S260,,
1820,1280,74LS181,,
1820,1281,74LS139,,
1820,1282,74LS109,,
1820,1283,74LS595BN,* LSTTL IC,
1820,1285,74LS54,,
1820,1288,8241 ? ,Quad 2 input Xor ?~?,
1820,1296,74LS295,,
1820,1297,74LS266,,
1820,1298,74LS251,,
1820,1300,74LS195,,
1820,1301,74S257,,
1820,1304,74S194,,
1820,1307,74S132,,
1820,1322,74S02,,
1820,1323,74S30,,
1820,1348,MM5307N,Baud Rate Gen,
1820,1358,93L34PC,Latch,
1820,1367,74S08N,,
1820,1402,74LS365,,
1820,1411,74LS75,,
1820,1412,4556,,
1820,1414,74LS12N,,
1820,1415,74LS13N,* LSTTL IC,
1820,1416,74LS14 ?,101P,
1820,1418,SN74LS42J,LSTTL IC,
1820,1419,74LS85,,
1820,1422,74LS122,,
1820,1423,74LS123,,
1820,1425,74LS132,,
1820,1427,74LS156N,,
1820,1428,74LS158,* LSTTL IC,
1820,1430,74LS161,,
1820,1433,74LS164,,
1820,1435,74LS669,,
1820,1437,74LS221,,
1820,1438,74LS257,,
1820,1439,74LS258,,
1820,1440,74LS279,,
1820,1441,74LS283,,
1820,1442,74LS290,* LSTTL IC,
1820,1443,74LS293,,
1820,1444,74LS298,,
1820,1445,74LS375N,,
1820,1447,74LS670,,
1820,1449,74S32N,,
1820,1451,74S38,* STTL IC,
1820,1453,74S163,,
1820,1469,74LS107,,
1820,1470,74LS157,,
1820,1478,74LS93N,,
1820,1486,4081,,
1820,1491,74LS367,,
1820,1492,74LS368,,
1820,1563,74C175,?,
1820,1568,74LS125,,
1820,1584,8046 ?,20 PIN,
1820,1633,74S240,,
1820,1641,74LS365,,
1820,1645,74LS126,,
1820,1655,74C906,Hex buffer,
1820,1673,SN97558N,,
1820,1676,74S373,,
1820,1689,MC3446,GPIB Buffer,
1820,1701,Intel 8080A,* Microprocessor,
1820,1729,74LS259,,
1820,1730,74LS273,,
1820,1745,4001,,
1820,1746,4049,,
1820,1747,mc14011bcp,2i/p nand cmos,
1820,1753,74C74,,
1820,1804,MPQ6842,Transistor Array,
1820,1810,MC3460,Clock Driver,
1820,1851,74LS148,,
1820,1897,mc14024bcp,7 stage cmos counter,
1820,1905,74S260,,
1820,1917,74LS240,,
1820,1918,74S241,,
1820,1932,4538,,
1820,1943,74S169,4028 ? Or 74S169,
1820,1960,4012,,
1820,1962,4028,CMOS Decoder,
1820,1963,mc14013bcp,dual d flip flop,
1820,1964,4027,,
1820,1970,4071,,
1820,1989,74LS393,,
1820,1991,74LS390N,,
1820,1997,74LS374,,
1820,2008,mc14015bcp,parallel out shift reg. dual 4 bit cmos,
1820,2012,SN74S373N,LSTTL IC,
1820,2013,4016,,
1820,2015,mc14070bcp,quad xor cmos,
1820,2024,74LS244,,
1820,2031,4014,,
1820,2037,mc14081bcp,2i/p and cmos,
1820,2044,74LS244,,
1820,2058,MC3448,GPIB Buffer,
1820,2075,74LS245,,
1820,2076,D3242,Dynamic Ram Address mux,
1820,2078,74LS490,,
1820,2096,74LS393,,
1820,2099,6802,Microprocessor ?,
1820,2102,74LS373,,
1820,2111,SN75468N,DRIVER IC,
1820,2117,9636,Line Driver,
1820,2177,8243,I/O expander,
1820,2198,9637,Line Receiver,
1820,2199,9638,Line Driver,
1820,2204,6402,UART,
1820,2206,74LS640,,
1820,2208,75462,,
1820,2210,74C00,,
1820,2211,74C04,,
1820,2215,74C373,,
1820,2216,74C374,,
1820,2220,4076,,
1820,2232,4034,,
1820,2268,74LS645,,
1820,2298,Z8400A,Z80A CPU?,
1820,2357,74C244,,
1820,2466,7555,CMOS timer,
1820,2483,75161,GPIB Control Buffer,
1820,2485,75160,GPIB Data Buffer,
1820,2488,74ALS74,,
1820,2505,68000,CPU (may be 68010),
1820,2506,74F04,,
1820,2520,75463,,
1820,2531,8250,UART,
1820,2536,74LS352,,
1820,2538,74C240,,
1820,2547,75162,GPIB Control Buffer,
1820,2548,9914,GPIB Controller,
1820,2549,8291,GPIB Interface,
1820,2557,74AS804,line driver,
1820,2564,8041,Peripheral Controller HP9836,
1820,2566,74C240,,
1820,2577,6551,Serial Chip,
1820,2621,74S255,,
1820,2622,74LS624,,
1820,2624,68B09,Microprocessor,
1820,2634,74ALS04,,
1820,2635,74ALS08,,
1820,2649,Z80B CPU,Microprocessor,
1820,2656,74ALS00,,
1820,2657,74ALS32,,
1820,2673,3870,"""Microcontroller 82165 GPIO""",
1820,2692,74F86,,
1820,2698,74F240,,
1820,2718,8039,ROMless microcontroller,
1820,2724,74ALS573,,
1820,2737,8048,Programmed for 82163 video interface,
1820,2739,74ALS02,,
1820,2740,74LS688,,
1820,2772,74ALS112,,
1820,2774,74ALS20,,
1820,2775,74ALS10,,
1820,2809,3870,"""Microcontroller 82165 GPIO""",
1820,2813,MM58167,Real Time Clock,
1820,2861,74F138,,
1820,2862,DS3667,,
1820,2948,8088-2,8MHz CPU,
1820,2960,COM8116,Baud Rate Generator,
1820,2975,C-2000,"""Gate Array backplane 27110 HPIB etc""",
1820,2983,68B21,PIA,
1820,2998,74HC373,,
1820,3084,8048,Programmed for 82169 HPIB interface,
1820,3089,7201,NEC Serial Chip,
1820,3100,74ALS138,,
1820,3121,74ALS245,,
1820,3167,74LS592,,
1820,3217,74ALS569,,
1820,3218,8048,Programmed for 82164 RS232,
1820,3258,74ALS137,,
1820,3267,C2000 Masked,Gate Array 98196 Mux,
1820,3321,1489,,
1820,3322,1488,,
1820,3331,Z8530,Serial Comms Controller,
1820,3358,16R6,PAL,
未完结,1楼后续!
 楼主| 发表于 2012-3-26 00:22:25 | 显示全部楼层
1820,3359,16R4,PAL,
1820,3378,74ALS373,,
1820,3420,PAL16L8,HP150 RAM Card,
1820,3431,75160,,
1820,3439,74ALS253,,
1820,3443,74AS808,,
1820,3465,74ALS174,,
1820,3466,74ALS175,,
1820,3467,74ALS832,,
1820,3513,75161,,
1820,3542,74AS373,,
1820,3545,80C96,,
1820,3608,74AS04,,
1820,3636,8048L,HPIB Thinkjet I/O PCB,
1820,3659,WD2793,Disk Controller,
1820,3695,74AS374,,
1820,3707,74ALS541,,
1820,3730,74AS08,,
1820,3766,WD2010,Hard Disk Controller,
1820,3825,Z8536,Parallel/Counter,
1820,3828,AM7990,,
1820,3883,Kaze,HP150-II Graphics Gate Array,
1820,3905,74ALS623,,
1820,3926,68000,10MHz,
1820,3936,8049,RS232 Thinkjet I/O PCB,
1820,3957,Pamela,HP150-II Memory gate array,
1820,4092,8742,HP150-II HP-HIL System,
1820,4192,PAL16R8,98625 GPIB card,
1820,4193,PAL16L8,98625 GPIB card,
1820,4194,16R4,LANIC,
1820,4195,16R6,LANIC Ethernet,
1820,4213,PAL20R8,98625 GPIB card,
1820,4222,Z8611-12,Masked Microcontroller 27110 HPIB,
1820,4401,AM7992,,
1820,4765,HAL16L8,HP150 Expanded RAM card,
1820,4766,HAL20X8,HP150 Expanded RAM card,
1820,4767,PAL20L10,HP150 Expanded RAM card,
1820,4768,PAL20L10,HP150 Expanded RAM card,
1820,4875,16R8,"""PAL 27110 HPIB",
1820,5980,16R6,"""PAL Lanic",
1820,5992,AM9516,,
1820,0018,??,"""Op-amp standard pinout",
1820,0051,uA702,Op-amp,
1820,0054,7400N,,
1820,0055,7490,TTL COUNTER,
1820,0056,7492,TTL COUNTER,
1820,0063,7451,,
1820,0068,7410,TTL GATE,
1820,0069,7420,,
1820,0070,7430,,
1820,0071,7440,TTL BUFFER,
1820,0072,7450,TTL ,
1820,0074,7454,,
1820,0075,7473,* TTL FF,
1820,0077,7474,* TTL DUAL D FF,
1820,0084,7453,,
1820,0085,7460,,
1820,0093,??,HP custom decade counter - like 7490,
1820,0094,6903 (SIM 7400),* DTL ,
1820,0099,7493,* TTL COUNTER,
1820,0107,??,Interface Buffer,
1820,0116,??,HP custom latch - like 7475,
1820,0125,711 ?,Dual Comparator,
1820,0174,7404,* TTL HEX INVERTER,
1820,0175,7405,,
1820,0196,uA723,* VOLTAGE REGULATOR (TO-99),
1820,0203,SL8940,"""Op-Amp ext comp Standard pinout",
1820,0223,??,"""Op-Amp ext comp Standard pinout",
1820,0233,74193,* TTL COUNTER,
1820,0244,SL701,Op-amp,
1820,0245,SL702,Op-amp,
1820,0250,??,6 Bit Comparator - 5055 Printer,
1820,0258,8193,DTL Dual JK flip-flop,
1820,0261,74121,* TTL ONE-SHOT,
1820,0269,7403,,
1820,0281,74107N,,
1820,0282,7486,* TTL GATE,
1820,0294,74164,,
1820,0321,uA710,* COMPARATOR (TO-99),
1820,0328,7402,,
1820,0348,4506,DTL Dual 4-input NAND,
1820,0363,7482,,
1820,0364,7491,,
1820,0370,74H00,,
1820,0371,74H10,,
1820,0373,74H20,,
1820,0376,74H40,,
1820,0380,74H53,,
1820,0383,74H60,,
1820,0386,74H71,,
1820,0430,78H05,TO3,
1820,0443,14960,Looks like 7493?,
1820,0468,74S45,16 PIN,
1820,0471,7406 ?,14 PIN,
1820,0477,/727??,8 PIN NAT SEMI,
1820,0478,??,"""Op-Amp ext comp TO99 Standard pinout",
1820,0493,LM307,Op amp,
1820,0495,B105 ?,24 PIN,
1820,0509,MC1488L,* RS232 DRIVER,
1820,0511,7408?,14 PIN,
1820,0513,7409,,
1820,0514,7426,,
1820,0535,SN55451BP,DRIVER IC,
1820,0537,7413?,,
1820,0567,MC4024,Dual VCO ?,
1820,0583,74L00,,
1820,0584,74L02,,
1820,0586,74L04,,
1820,0587,74L10,,
1820,0590,74L51,,
1820,0591,74L54,,
1820,0594,74L72,,
1820,0595,74L73,,
1820,0596,74L74,,
1820,0599,74L95,,
1820,06?1?,74s64n,,
1820,0620,74153,,
1820,0621,7438,,
1820,0622,74151,,
1820,0627,93L01??,BCD-Dec decoder,
1820,0627,93L0159??,* LTTL IC BCD TO DEC DECODER,
1820,0629,74S112N,,
1820,0640,74150,,
1820,0655,7425,,
1820,0656,74L98,,
1820,0658,93L12DC,Mux,
1820,0668,7407 ?,14 PIN,
1820,0681,74S00N,,
1820,0682,74S03,,
1820,0683,74S04N,,
1820,0684,74S05,,
1820,0685,74S10,,
1820,0686,74S11,,
1820,0688,74S20N,,
1820,0693,74S74N,,
1820,0702,93L1159,1-16 decoder,
1820,0704,74122,,
1820,0706,9324,5-bit comparator,
1820,0710,SL17315=74157,Mux,
1820,0716,74161,,
1820,0742,,8 * D type Flip Flop or Latch,
1820,0744,7497,,
1820,0777,?74L42,BCD-Decimal decoder,
1820,0788,SN35431=74174?,,
1820,0798,??,HP custom - 6 decade counter,
1820,0799,75452,,
1820,0839,74175,,
1820,0876,74L75,,
1820,0904,93L24,Comparator,
1820,0939,4013,,
1820,0946,QQ8042 ?,14 PIN,
1820,0981,,14 PIN,
1820,0990,1489,RS232 Receiver,
1820,1016,75453,,
1820,1487,,Logic Pulsar IC - 546A,
1820,1600,4093,quad schmitt input NAND,
1820,1610,,Logic Probe IC - 545A,
1820,1688,74LS247,BCD - 7SEG,
1820,2131,MC3870P,,
1820,2132,ICM7218A,LED DRIVER,
1820,2139,,Multiple Register Counter? - 5315B Counter?,
1820,2171,,ECL Pre Scaler,
1820,4790,74ALS245 - SMD ,Surface mount octal Tristate Transceiver,
1820,5053,74F125 - SMD,Surface mount buffer ,
1820,5950,74AC04 - SMD,Surface mount hex inverter,
1820,5934,74AC138 - SMD,Surface mount 3 - 8 demux,
1820,6066,74AC245 - SMD ,Surface mount octal Tristate Transceiver,
1820,0256,MC858,DTL Quad 2-input NAND,
1821,0001,CA3046,5 NPN TRANSISTORS,
1826,1014,78H12,,
1826,1218,7824,,
1826,0009,??,"""Opamp ?? - TO99",
1826,0051,,14 PIN,
1826,0059,LM201,,
1826,0064,uA733,AMPLIFIER IC,
1826,0065,LM311P,COMPARATOR IC,
1826,0065,LM311,,
1826,0072,LM208,,
1826,0081,LM318,TO99 Package,
1826,0089,??,"""Op-Amp TO 99",
1826,0106,7815,,
1826,0111,,METAL CAN,
1826,0122,7805,,
1826,0123,,TO3,
1826,0138,SM340 /LM339,14 PIN,
1826,0147,7812,,
1826,0167,CA3094,TO99 Package,
1826,0174,MC3302,14 PIN,
1826,0174-1,MC3302,14 PIN,
1826,0180,555,,
1826,0181,78H05,,
1826,0188,MC1408,8-BIT DAC,
1826,0194,NE592,,
1826,0210,NE527,Comparator - NE529??? LM361,
1826,0214,7915,,
1826,0271,741,,
1826,0291,LM324,Quad Op amp,
1826,0294,7912,,
1826,0346,LM358,Dual Op amp,
1826,0357,LF357,OP AMP IC,
1826,0393,LM317T,,
1826,0412,LM393,DUAL COMPARATOR IC,
1826,0424,MC3405P,Dual Op amp,
1826,0426,AM687ADL,Dual Comparator,
1826,0450,TL497,Voltage reg,
1826,0467,MC1403P1,Voltage Ref precision,
1826,0493,LM308,,
1826,0522,TL074,Quad Op-Amp,
1826,0527,LM337T,,
1826,0544,MC1403,Voltage ref,
1826,0589,,,
1826,0635,OP-07CP,,
1826,0698,AD590JH,Temperature Sensor,
1826,0719,LM346,,
1826,0774,LM385BZ,,
1826,0822,AD524KH,Instrumentation Op-amp,
1826,0903,MC1372,Video Modulator,
1826,0904,LM330T-5.0,,
1853,0012,2N2904A,* TRANSISTOR ,
1853,0031,2N3789,* TRANSISTOR ,
1853,0036,,Transistor PNP 310mW 250Mhz,
1853,0045,2N 4036,Metal can,
1853,0051,2N4037,TRANSISTOR ,
1853,0258,2N4035,* PNP TRANSISTOR ,
1853,0312,2N5160,* PNP TRANSISTOR ,
1853,0363,X45H281,50W PNP Transistor,
1853,0389,,350mW PNP TO-92 Transistor,
1853,0414,2N6423,* TRANSISTOR ,
1853,0412,,Transistor PNP ,
1854,0012,2N2904A,TRANSISTOR ,
1854,0039,2N3053,TRANSISTOR ,
1854,0053,2N2218,TRANSISTOR ,
1854,0063,2N3055,* NPN TRANSISTOR ,
1854,0345,2N5179,* NPN TRANSISTOR ,
1854,0477,2n2222A,to18 NPN Transistor,
1854,0743,2N5878,* NPN TRANSISTOR ,
1854,0784,2N3866A,* NPN TRANSISTOR ,
1854,0809,2N2369A,* NPN TRANSISTOR ,
1854,0955,2N5662,TRANSISTOR TO-5,
1854,0699,,Transistor NPN 30W,
1855,0213,,Dual Jfet N chan D mode TO78,
1855,0228,,Jfet N chan D mode TO-92,
1858,0040,CA3127,Transistor Array,
1858,0044,MPQ3904 (?),* 4 NPN TRANSISTORS ,
1858,0047,uln2003an,npn darlington trnsistor array,
1858,0050,CA3082,NPN 7-transistor array,
1858,0058,TPQ3906,? 4 PNP Transistors,
1858,0097,ULN2023A,,
1858,0099,MC1413,7 Drivers,
1901,0050,,Diode Switching 80V 200mA 2nS,
1901,0511,iN3889,FAST RECTIFIER,
1LB3,0003,?,HPIL Chip,
1LF4,0001,?,"""Video Chip 82163",
1LG7,0064,?,"""Saturn ROM",
1LH4,0001,?,"""HPIB Buffer 40 Pin",
1LJ7,0014,Saturn,"""CPU Centronics and RS232 Thinkjet",
1LJ7,0015,Saturn,"""CPU HPIL and HPIB Thinkjet",
1LJ7,0024,Saturn,"""CPU Portable Parallel Thinkjet""",
1QF6,0066,?,"""ADC Hybrid 3421 DAQ unit""",
1QH5,0085,?,"""Input Hybrid 3421 DAQ unit""",
1RD2,6001,Cerberus,HP-HIL Master Chip,
1RE3,0001,Pacific,HP150-II Alpha Video Gate Array,
1TL1,0001,Medusa,HPIB Controller (48 pin DIP),
1TL1,0006,Medusa,HPIB Controller,
 楼主| 发表于 2012-3-26 00:31:22 | 显示全部楼层
附:庞大的惠普带换件库PDF文档   庞大的惠普带换件库.pdf (46 KB, 下载次数: 85)
发表于 2012-3-26 00:41:42 | 显示全部楼层
支持楼主的共享精神[s:31] [s:31] [s:31]
 楼主| 发表于 2012-3-26 01:31:43 | 显示全部楼层
回 bosch 的帖子
bosch:支持楼主的共享精神[s:31] [s:31] [s:31]  (2012-03-26  00:41)
与人方便,方便自己[s:7]
发表于 2012-3-26 02:29:09 | 显示全部楼层
感谢楼主分享
 楼主| 发表于 2012-3-26 10:29:21 | 显示全部楼层
回 iking921 的帖子
iking921:感谢楼主分享 (2012-03-26  02:29)
您客气了,大家需要来拿。。。
发表于 2012-3-26 11:24:21 | 显示全部楼层
谢谢分享!!!
发表于 2012-3-26 12:06:33 | 显示全部楼层
感谢分享!
 楼主| 发表于 2012-3-26 12:49:34 | 显示全部楼层
回 大胡子 的帖子
大胡子:谢谢分享!!! (2012-03-26  11:24)
您客气了,大家需要来拿。。。
 楼主| 发表于 2012-3-26 12:50:11 | 显示全部楼层
回 tudou204 的帖子
tudou204:感谢分享! (2012-03-26  12:06)
您客气了,大家需要来拿。。。
