查看: 1192|回复: 0
MOTOROLA 手持密钥管理终端
发表于 2016-10-20 17:08:55 | 显示全部楼层 |阅读模式
价格1800 运费15淘宝链接
MOTOROLA 手持密钥管理终端(裸机,不含电池,不含线,赠送用户手册)
数据线可以单买,100元/个(最后两张是数据线的图片)
该终端具有读取\注入\计算功能
对于摩托手持\车载电台均可以进行加密控制
如:XTS2500 XTS3000 XTS5000 SEE5000  SABER /ASTRO SABER  SABER /ASTRO SPECTRA /XTL1500 /XTL2500 /XTS5000 /XTS7500 /APX6000 /APX7000 还有各类军用电台
手台中安装有硬件加密板后,通过CPS无法对其进行设置。需要通过手持密钥管理终端进行加密写入。加密终端分为固件和选件2部分。
固件R01.XXX仅支持模拟系统加密
固件R02.XXX可以支持ASTRO 25系统加密
本终端固件版本 R02.05.11
加密选件 :DES , DES-XL , DES-OFB
本机器支持ASTRO 25数字/模拟加密系统。回去可以直接使用。提供完整使用手册。机器无修无进水。屏幕完美不缺划。机器还有更多的功能,需要自己回去研究了。包括高级密钥、多密钥控制、OTAR Systems、Performing Initial Programming等。
Motorola Key Variable Loader
The KVL-3000 (or T5795A) is a device for loading cryptographic material (key variables) into a series of two-way radios, developed and produced by Motorola (USA) around 2001. The system can be used for a variety of cryptographic algorithms and is compatible with a range of radios.
A Key Variable Loader, or KVL, is commonly known as a Key Filler or Fill Gun, and generally uses a proprietary data protocol for transferring cryptographic material (keys) to the radio.
Initially, Motorola had a separate Key Variable Loader (KVL) for each individual cryptographic algorithm, such as DVP, DES and DES-XL, but these were eventually all replaced by the KVL-3000 and the KVL-3000 Plus. The difference between these two versions is that the earlier KVL-3000 has a 4-line 12-character display, whilst the Plus has a bitmap (matrix) display.
Operating the KVL-3000
The KVL-3000 has two modes of operation: Advanced Securenet (ASN) and ASTRO 25. ASN mode is needed, for example, for loading keys into the older SABER I, II and III hand-held radios. The required mode can be selected via the CONFIG menu. A special cable, that is different for each type of radio, connects the Keyload I/O port at the rear of the KVL to the accessory socket of the radio. The case design of the KVL-3000 is patented by Motorola.
Versions
? KVL-3000
This is the initial version of the KVL-3000. It has a display with 4 lines of 12 characters each, plus a row of icons at the top. It can be used for loading key variables for the common Motorola encryption algorithms: DES, DVP, DES-XL, DVP-XL and DVI-XL. a
? KVL-3000 Plus
This is a slightly later version of the KVL-3000 that is equipped with a matrix display (bitmap), allowing icons and graphics to be displayed. This version is suitable for all of the earlier protocols2 plus AES-256 and DES-OFB. Please note that this version does not support the DVP encryption algorithm (it does support DVP-XL however).
1. Please note that only two algorithms can be installed in a KVL-3000 at the time of ordering, and that many of them come with just one algorithm installed (DES). Be aware of this when buying via eBay.
Furthermore it supports the following encryption protocols:
? 12 Kb/s SECURENET ?
? 9.6 Kb/s Secure ASTRO ?, with VSELP Vocoder
? 9.6 Kb/s Secure APCO Project 25 (IMBE Vocoder)
The following encryption standards are supported:
? FIPS 46-2
? FIPS 81
? FIPS 140-2
Features
? Password protection (operator and supervisor)
? Can hold up to 1024 encryption keys (traffic keys and shadow keys)
? Menu-driven User Interface
? Software upgrades via PCMCIA card slot and Motorola FLASHportTM
? Various encryption algorithms (see above)
? Various encryption protocols (see above)
? Supports various FIPS encryption standards (see above)
? RS-232 and Keyload I/O ports
? Supports serial and PCMCIA modems
? Key sharing between KVLs
? Event log of KVL activities
? Supports transfer to/from Key Management Controller (KMC)
Glossary
ASN     Advanced Securenet
DES     Data Encryption Standard
Universal encryption algorithm developed in the mid-1970s by the US National Security Agency (NSA) for the protection of voice, data and financial transactions. Although initially intended for use exclusively by the US Government, it ws later released for use by the general public. (Wikipedia)
KVL     Key Variable Loader
OFB     Output feedback
a block cipher mode that modifies ECB mode to operate on plaintext segments of variable length lesss than or equal to the block length.
150425223393270ca360e40f50.jpg 1.jpg 2.jpg 3.jpg 4.jpg 5.jpg 6.jpg 7.jpg 8.jpg 9.jpg 10.jpg 11.jpg 12.jpg 13.jpg 14.jpg IMG_20161020_111415.jpg IMG_20161020_111437.jpg
售出不退换 请考虑后购买
发表于 2016-10-20 19:14:23 38hot手机频道 | 显示全部楼层
神器,去hellocq试试看有没有人要
