查看: 472|回复: 0
过期文档-2
发表于 2016-10-20 09:43:04 | 显示全部楼层 |阅读模式
high speed timer
    pulse top (Volts): 0.0974999992
    pulse base (Volts): -0.000156252238
    pulse width (Secs):   9.75e-09
    delay search value:          1
    trigger freq (Hz): 1600006.83
    delay search value:       2049
    trigger freq (Hz): 1600006.25
    delay search value:       3073
    trigger freq (Hz): 1600006.48
    delay search value:       3585
    delay search value:       3841
    trigger freq (Hz):          0
    delay search value:       3713
    trigger freq (Hz): 1600006.36
    delay search value:       3777
    delay search value:       3745
    delay search value:       3729
    delay search value:       3737
    trigger freq (Hz):   811901.7
    delay search value:       3741
    trigger freq (Hz): 3184.68801
    delay search value:       3739
    trigger freq (Hz): 115520.743
    delay search value:       3740
    trigger freq (Hz): 20431.5293
    GT DAC threshold value:  0xe9c
    delay search value:       4095
    trigger freq (Hz): 1600007.53
    delay search value:       2047
    delay search value:       3071
    delay search value:       3583
    delay search value:       3839
    trigger freq (Hz): 1600007.64
    delay search value:       3711
    delay search value:       3775
    delay search value:       3743
    trigger freq (Hz): 1600006.71
    delay search value:       3727
    delay search value:       3735
    trigger freq (Hz): 194921.246
    delay search value:       3731
    delay search value:       3733
    trigger freq (Hz): 10952.8064
    LT DAC threshold value:  0xe95
    gt reference delay (Secs): -9.71897655e-09
    lt reference delay (Secs): -9.54704433e-09
    initial DAC search:  0xebd
    gt delay factor (nS, Hex):  2,   1949
    gt delay factor (nS, Hex):  3,   2861
    gt delay factor (nS, Hex):  4,   3089
    gt delay factor (nS, Hex):  5,   3337
    gt delay factor (nS, Hex):  6,   3486
    gt delay factor (nS, Hex):  7,   3558
    gt delay factor (nS, Hex):  8,   3648
    gt delay factor (nS, Hex):  9,   3710
    lt delay factor (nS, Hex):  2,   1934
    lt delay factor (nS, Hex):  3,   2853
    lt delay factor (nS, Hex):  4,   3083
    lt delay factor (nS, Hex):  5,   3335
    lt delay factor (nS, Hex):  6,   3445
    lt delay factor (nS, Hex):  7,   3558
    lt delay factor (nS, Hex):  8,   3638
    lt delay factor (nS, Hex):  9,   3688
low speed timer
    pulse top (Volts): 0.100624999
    digital delay search value:   0x40
    trigger freq: 1600007.06
    digital delay search value:   0x60
    trigger freq: 1600007.53
    digital delay search value:   0x70
    trigger freq:          0
    digital delay search value:   0x68
    trigger freq:          0
    digital delay search value:   0x64
    trigger freq: 1599506.71
    digital delay search value:   0x66
    trigger freq: 518926.769
    mixed SE threshold value:   0x66
    fast path used for mixed threshold
    bonanza reference delay (Secs): -9.56993318e-09
    mixed fast path factor: 3.83299364e-09
    mixed counter1 path factor: 7.5613855e-09
    SE gain factor: 5.74057164e-11
    pulse width (Secs):    4.7e-09
    trigger freq:          0
    digital delay search value:   0x50
    trigger freq:          0
    digital delay search value:   0x48
    trigger freq: 1600007.64
    digital delay search value:   0x4c
    trigger freq: 127785.257
    digital delay search value:   0x4a
    digital delay search value:   0x4b
    trigger freq: 1363481.39
    low speed SE threshold value:   0x4b
    fast path used for low speed threshold
    bonanza reference delay (Secs): -8.02088889e-09
    low speed fast path factor: 3.3312571e-10
    low speed counter1 path factor: 4.06056651e-09
    low Speed counter2 path factorn: 4.43164918e-09
