查看: 471|回复: 0
过期文档-1
发表于 2016-10-20 09:36:00 | 显示全部楼层 |阅读模式
chan 0 20 mV/Div linDivsPerTrigDiv 0.55605
05:36:29 12/09/2013 (thread: rtl)
linearity table offset 0.260931 divs
seg 0 tgt -0.75, cvr 0.221027, linDiv -6 --> int -0.750549, slp 0.12497
seg 1 tgt -0.625, cvr 0.185059, linDiv -5 --> int -0.62558, slp 0.124669
seg 2 tgt -0.5, cvr 0.149004, linDiv -3.99759 --> int -0.500911, slp 0.126323
seg 3 tgt -0.375, cvr 0.113145, linDiv -3.00061 --> int -0.374587, slp 0.125049
seg 4 tgt -0.25, cvr 0.0774805, linDiv -2.00906 --> int -0.249538, slp 0.122959
seg 5 tgt -0.125, cvr 0.0406445, linDiv -0.984929 --> int -0.126579, slp 0.123684
seg 6 tgt 0, cvr 0.00458984, linDiv 0.0174815 --> int -0.00289467, slp 0.127648
seg 7 tgt 0.125, cvr -0.0308789, linDiv 1.0036 --> int 0.124754, slp 0.122694
seg 8 tgt 0.25, cvr -0.0675195, linDiv 2.0223 --> int 0.247447, slp 0.123318
seg 9 tgt 0.375, cvr -0.103965, linDiv 3.03557 --> int 0.370765, slp 0.126324
seg 10 tgt 0.5, cvr -0.139238, linDiv 4.01626 --> int 0.49709, slp 0.12701
seg 11 tgt 0.625, cvr -0.174902, linDiv 5.00781 --> int 0.624099, slp 0.124986
seg 12 tgt 0.75, cvr -0.210589, linDiv 6 --> int 0.749085
trig 0 chan 0 cg 4 linDivsPerTrigDiv 0.556326
05:36:31 12/09/2013 (thread: rtl)
trig 0 chan 0 cg 4 linOffset 0.124956
trig 0 chan 0 cg 4 negSlopeOffset 0.129302
trig 0 chan 0 cg 4 noiseRejOffset (+) -0.131475
trig 0 chan 0 cg 4 noiseRejOffset (-) 0.259691
trig 0 chan 0 cg 4 normal hysteresis 0.121014 div
05:36:32 12/09/2013 (thread: rtl)
trig 0 chan 0 cg 4 HFREJ hysteresis 0.121014 div
trig 0 chan 0 cg 4 LFREJ hysteresis 0.121014 div
trig 0 chan 0 cg 4 noise rej hysteresis 0.356366 div
trig 0 chan 0 cg 0 linDivsPerTrigDiv 0.560729
05:36:34 12/09/2013 (thread: rtl)
trig 0 chan 0 cg 0 linOffset 0.165371
trig 0 chan 0 cg 0 negSlopeOffset 0.0208083
trig 0 chan 0 cg 0 noiseRejOffset (+) -0.121564
trig 0 chan 0 cg 0 noiseRejOffset (-) 0.139087
trig 0 chan 0 cg 1 linDivsPerTrigDiv 0.561144
05:36:36 12/09/2013 (thread: rtl)
trig 0 chan 0 cg 1 linOffset 0.11727
trig 0 chan 0 cg 1 negSlopeOffset 0.10631
trig 0 chan 0 cg 1 noiseRejOffset (+) -0.123846
trig 0 chan 0 cg 1 noiseRejOffset (-) 0.242213
trig 0 chan 0 cg 2 linDivsPerTrigDiv 0.55787
05:36:38 12/09/2013 (thread: rtl)
trig 0 chan 0 cg 2 linOffset 0.112228
trig 0 chan 0 cg 2 negSlopeOffset 0.138378
trig 0 chan 0 cg 2 noiseRejOffset (+) -0.118765
trig 0 chan 0 cg 2 noiseRejOffset (-) 0.271308
trig 0 chan 0 cg 3 linDivsPerTrigDiv 0.556733
05:36:40 12/09/2013 (thread: rtl)
trig 0 chan 0 cg 3 linOffset 0.120698
trig 0 chan 0 cg 3 negSlopeOffset 0.122873
trig 0 chan 0 cg 3 noiseRejOffset (+) -0.120698
trig 0 chan 0 cg 3 noiseRejOffset (-) 0.259881
trig 0 chan 0 cg 5 linDivsPerTrigDiv 0.557368
05:36:42 12/09/2013 (thread: rtl)
trig 0 chan 0 cg 5 linOffset 0.123013
trig 0 chan 0 cg 5 negSlopeOffset 0.120836
trig 0 chan 0 cg 5 noiseRejOffset (+) -0.129545
trig 0 chan 0 cg 5 noiseRejOffset (-) 0.262355
trig 0 chan 1 cg 4 linDivsPerTrigDiv 0.542901
05:36:44 12/09/2013 (thread: rtl)
trig 0 chan 1 cg 4 linOffset -0.124061
trig 0 chan 1 cg 4 negSlopeOffset 0.128303
trig 0 chan 1 cg 4 noiseRejOffset (+) -0.136786
05:36:45 12/09/2013 (thread: rtl)
trig 0 chan 1 cg 4 noiseRejOffset (-) 0.236459
trig 0 chan 1 cg 0 linDivsPerTrigDiv 0.544853
05:36:46 12/09/2013 (thread: rtl)
trig 0 chan 1 cg 0 linOffset -0.109609
05:36:47 12/09/2013 (thread: rtl)
trig 0 chan 1 cg 0 negSlopeOffset 0.0436308
trig 0 chan 1 cg 0 noiseRejOffset (+) -0.126636
trig 0 chan 1 cg 0 noiseRejOffset (-) 0.158561
trig 0 chan 1 cg 1 linDivsPerTrigDiv 0.543584
05:36:49 12/09/2013 (thread: rtl)
trig 0 chan 1 cg 1 linOffset -0.1136
trig 0 chan 1 cg 1 negSlopeOffset 0.105107
trig 0 chan 1 cg 1 noiseRejOffset (+) -0.147574
trig 0 chan 1 cg 1 noiseRejOffset (-) 0.228263
trig 0 chan 1 cg 2 linDivsPerTrigDiv 0.54117
05:36:51 12/09/2013 (thread: rtl)
trig 0 chan 1 cg 2 linOffset -0.13635
trig 0 chan 1 cg 2 negSlopeOffset 0.140577
trig 0 chan 1 cg 2 noiseRejOffset (+) -0.12578
trig 0 chan 1 cg 2 noiseRejOffset (-) 0.252617
trig 0 chan 1 cg 3 linDivsPerTrigDiv 0.541287
05:36:53 12/09/2013 (thread: rtl)
trig 0 chan 1 cg 3 linOffset -0.142722
trig 0 chan 1 cg 3 negSlopeOffset 0.127921
trig 0 chan 1 cg 3 noiseRejOffset (+) -0.134264
trig 0 chan 1 cg 3 noiseRejOffset (-) 0.248442
trig 0 chan 1 cg 5 linDivsPerTrigDiv 0.541824
05:36:55 12/09/2013 (thread: rtl)
trig 0 chan 1 cg 5 linOffset -0.121699
trig 0 chan 1 cg 5 negSlopeOffset 0.123815
trig 0 chan 1 cg 5 noiseRejOffset (+) -0.140747
trig 0 chan 1 cg 5 noiseRejOffset (-) 0.246572
