查看: 499|回复: 0
求助34970A自检报错ERR606怎么解决
发表于 2015-11-24 15:42:35 | 显示全部楼层 |阅读模式
我的34970A现在自检报错ERR606,看手册好像是ADC有问题,换过LM399,和LM399周边的8脚ADC转换芯片,现在不知道怎么下手了,请高手指点一下
606 Rundown gain out of range This test checks the nominal gain
between the integrating ADC and the A1U205 on-chip ADC. The
nominal gain is check to ± 10% tolerance.
