查看: 114|回复: 0
JDSU H301 H301-1510 H301-1210 H301-1110 10Gbs 中功率放大器
发表于 2015-5-22 09:05:50 | 显示全部楼层 |阅读模式
JDSU H301 H301-1510 75KHz-10GHz 增益26dB RF 射频微波超宽带中功率放大器
工作频率:75KHz-10GHz
输出功率:> 23dBm
增益:> 26dB  可增益控制14-26dB
工作电压:+8V /-5V
接头:2.92mm
官网下载资料
http://pdf.datasheetarchive.com/datasheetsmain/Datasheets-313/206350.pdf
电光调制器驱动模块  2.92mm接头
质量包好,包能用 可提供详细测试图
10 Gb/s Optical Modulator Driver  H301 Series
型号:JDSU H301    H301-1510
功能:实测正常
Key Features
• Low power, 4.9 W
• Low jitter
• Data rates from 2.488 to 12.2 Gb/s
Applications
• SONET/SDH equipment
• SR, IR, LR optical transmitters
成色:二手外观有正常使用痕迹,如下实物图
The H301 optical modulator driver provides a
high-quality, single-ended voltage to drive an
external laser modulator.  Typical applications
include driving EML, EAM, and Mach-Zehnder
style modulators. It amplifies 2.488 to 12.2 Gb/s
data input signals to >7.0 Vp-p drive levels.  The flat
gain and flat group delay response yield a high-
quality, low-jitter electrical drive signal. The driver
meets applicable SONET and SDH standards for
OC-192 10 Gb/s optical transmitters and includes
reference and detector outputs to enable external
temperature-compensated control of output drive
levels. The module has field replaceable input and
output K-connectors for the input/output drive
signals and an eight-pin connector for the detector,
reference, and power interfaces.
发表于 2015-5-22 09:47:20 | 显示全部楼层
几块钱
 楼主| 发表于 2015-5-22 09:51:36 | 显示全部楼层
2200.00/只
