主要技术指标和功能
Altitude: Up to 15,000 feet (4572 m)
Data Transfer: 9 pin-RS-232 (DB9), compatible with serial port
Dimensions: 10.5" x 8.4" x 3.3" (265 mm x 212 mm x 83 mm)
External AC: 90 to 264 Vac @ 45-66 Hz; AC/DC adapter required
External DC: 9-16 VDC fused, <3 A
Frequency Range: 780-2500 MHz
Frequency Resolution: 50 kHz
Humidity: 95% ± 5% max. (non-condensing)
Immunity to Interfering Signals: Rejects on-frequency signals up to +13 dBm
Impedance: 50 Ohms
Internal Time: Rechargable Lithium-Ion batteries, 3 hour minimum operating time. Auto shut
-off conserves battery life.
Maximum Input Signal: +22 dBm
Operating Temp.: -10°C to 50°C (14°F to 122°F)
Power Measurement: Yes
Return Loss: 0 to -60 dB
Setup Storage Capacity: 15-Set-Ups/(500) 238 ponit traces
Speed: 1 multi-frequency scan (238 points)/2 seconds; 1 multi-frequency scan (475
points)/3.5 seconds; 1 multi-frequency scan (949 points)/6 seconds
Storage Temperature: -40°C to 80°C (-40°F to 176°F)
Test Port: N-type female connector
