楼主: lymex
我的文集(2016-7-9最后更新) lymex文集
发表于 2009-7-19 09:47:30 | 显示全部楼层 |阅读模式
为了查找方便,把我在这里发的帖子分类索引一下。
所有我的帖子,除了个别的段落属于引用(并注明)外,均为原创。转载请注明出处和作者。
1、通用计量部分
直流计量的一些相关国家标准 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4782
单位与单位制 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1057
基准爱好者必备仪器 https://bbs.38hot.net/forum.php?mod=viewthread&tid=330
匹配的10%法则 https://bbs.38hot.net/forum.php?mod=viewthread&tid=209
如何在Excel里不等间隔数据做图 https://bbs.38hot.net/forum.php?mod=viewthread&tid=138
利用二元相关分析,同时得到温度系数和老化 https://bbs.38hot.net/forum.php?mod=viewthread&tid=135
常年开机电压基准的热成像 https://bbs.38hot.net/forum.php?mod=viewthread&tid=67663
2、万用表部分
MX-DIY 6.5位手持表测试 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4594
从3458A电路推出R-2R DAC通用转换公式 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4104
Keithley 2002 八位半 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1228
几个8位半的短稳测试 https://bbs.38hot.net/forum.php?mod=viewthread&tid=719
explorer的3458A https://bbs.38hot.net/forum.php?mod=viewthread&tid=649
高精度万用表的测试 https://bbs.38hot.net/forum.php?mod=viewthread&tid=643
bg1grn的3458A https://bbs.38hot.net/forum.php?mod=viewthread&tid=436
高位表测量的干扰与防护 https://bbs.38hot.net/forum.php?mod=viewthread&tid=434
高位表的真欧姆  https://bbs.38hot.net/forum.php?mod=viewthread&tid=382
我的Advantest R6871E-DC 7位半万用表 https://bbs.38hot.net/forum.php?mod=viewthread&tid=253
爱得万八位半万用表Advantest R6581T https://bbs.38hot.net/forum.php?mod=viewthread&tid=212
德国GMC MetraHit 30M 手持6位半 https://bbs.38hot.net/forum.php?mod=viewthread&tid=181
双基准校准HP3458A八位半万用表 https://bbs.38hot.net/forum.php?mod=viewthread&tid=67
Agilent 3458A 八位半万用表基准的改动与校准 https://bbs.38hot.net/forum.php?mod=viewthread&tid=47
3、电压基准部分
实例说明电压基准的测量、标定和对比 https://bbs.38hot.net/forum.php?mod=viewthread&tid=167842
我也做个噪声仪 https://bbs.38hot.net/forum.php?mod=viewthread&tid=159569
打理 Fluke 335D  https://bbs.38hot.net/forum.php?mod=viewthread&tid=12602
直流高压  https://bbs.38hot.net/forum.php?mod=viewthread&tid=11133
100V基准   https://bbs.38hot.net/forum.php?mod=viewthread&tid=10827
thy888漂流电压基准测试  https://bbs.38hot.net/forum.php?mod=viewthread&tid=9169
bg1grn's 4910维修案例 https://bbs.38hot.net/forum.php?mod=viewthread&tid=6581
AEON两个10V基准的测试  https://bbs.38hot.net/forum.php?mod=viewthread&tid=3420
几篇国内电压基准DIY的文章及评价 https://bbs.38hot.net/forum.php?mod=viewthread&tid=3360
有关电压基准的一个故事-------加速老化测试可靠吗? https://bbs.38hot.net/forum.php?mod=viewthread&tid=3353
电压基准的测试 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1363
超级基准DIY历史  https://bbs.38hot.net/forum.php?mod=viewthread&tid=1276
4910的电源原理与锂电替换 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1023
基准噪音问答 https://bbs.38hot.net/forum.php?mod=viewthread&tid=998
电压基准测试系统 https://bbs.38hot.net/forum.php?mod=viewthread&tid=829
7V和10V基准的测试 https://bbs.38hot.net/forum.php?mod=viewthread&tid=645
低电压/纳伏电压/低压测量 https://bbs.38hot.net/forum.php?mod=viewthread&tid=270
SZA263/LTFLU-1的原理和外围器件 https://bbs.38hot.net/forum.php?mod=viewthread&tid=177
DIY高准确度电压基准--- https://bbs.38hot.net/forum.php?mod=viewthread&tid=46
常见稳压器件特性比较表 https://bbs.38hot.net/forum.php?mod=viewthread&tid=6
固态电压基准 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4
如何精确的测量电压和电阻 https://bbs.38hot.net/forum.php?mod=viewthread&tid=3
10V基准做法说明 https://bbs.38hot.net/forum.php?mod=viewthread&tid=2
4、电阻基准部分
标准电阻的温度系数补偿(Beta系数补偿) https://bbs.38hot.net/forum.php?mod=viewthread&tid=167995
超高精度高值电阻桥(新版) https://bbs.38hot.net/forum.php?mod=viewthread&tid=153910
Excel辅助-标准电阻测量计算 https://bbs.38hot.net/forum.php?mod=viewthread&tid=152208
标准电阻和精密电阻的精细调节 https://bbs.38hot.net/forum.php?mod=viewthread&tid=152023
小阻值电阻的并联 https://bbs.38hot.net/forum.php?mod=viewthread&tid=10664
一款全新的高阻电桥检流计 https://bbs.38hot.net/forum.php?mod=viewthread&tid=9989
用Vishay 金封金属箔DIY 10k标准电阻 https://bbs.38hot.net/forum.php?mod=viewthread&tid=9090
DIY 100k哈蒙 https://bbs.38hot.net/forum.php?mod=viewthread&tid=5552
DIY 标准电阻之温度系数补偿 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4928
哈蒙(Hamon)电阻传递标准  https://bbs.38hot.net/forum.php?mod=viewthread&tid=4776
高联9975 DCC 电阻电桥 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4488
高阻及其测试 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4453
100 欧标准电阻测试平台 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4312
10k 电阻基准测试结果 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4115
JRL DCC-C高精度电阻测试系统 https://bbs.38hot.net/forum.php?mod=viewthread&tid=2824
精确测试标准电阻SR104的温度系数 htthttps://bbs.38hot.net/forum.php?mod=viewthread&tid=1352
四线电阻测量,怎么个量法? https://bbs.38hot.net/forum.php?mod=viewthread&tid=369
DIY 1GΩ 标准电阻 https://bbs.38hot.net/forum.php?mod=viewthread&tid=305
精密电阻排行榜 https://bbs.38hot.net/forum.php?mod=viewthread&tid=291
小值电阻 https://bbs.38hot.net/forum.php?mod=viewthread&tid=233
超高精密电阻VHP202Z拆解图 https://bbs.38hot.net/forum.php?mod=viewthread&tid=147
标准电阻 https://bbs.38hot.net/forum.php?mod=viewthread&tid=142
[新版] 精密电阻分类特性 https://bbs.38hot.net/forum.php?mod=viewthread&tid=139
自制Hamon量具 https://bbs.38hot.net/forum.php?mod=viewthread&tid=112
精密电阻测量仪器与自制Warshawsky电桥 https://bbs.38hot.net/forum.php?mod=viewthread&tid=27
5、分压
Excel 辅助设计7转10电路:补偿温漂和电压值 https://bbs.38hot.net/forum.php?mod=viewthread&tid=151500
有关最高等级的精密分压器 https://bbs.38hot.net/forum.php?mod=viewthread&tid=137
6、开关、扫描器
电阻基准测试用无电源4线扫描器 https://bbs.38hot.net/forum.php?mod=viewthread&tid=4041
电压基准测试比较用开关/扫描器 https://bbs.38hot.net/forum.php?mod=viewthread&tid=3658
2×4测量开关 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1186
Data Proof 160A 开关/扫描器的内部结构与改动 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1082
测量开关和扫描器  https://bbs.38hot.net/forum.php?mod=viewthread&tid=1016
干脆先做个机械开关 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1006
7、测试线、接线柱
接线柱及其连接 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1358
几种测试线的绝缘电阻 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1153
我的DIY测试线 https://bbs.38hot.net/forum.php?mod=viewthread&tid=100
双芯单股Teflon的屏蔽测试线的制作方法 https://bbs.38hot.net/forum.php?mod=viewthread&tid=16
8、电流
低压1.1V启动二端10A恒流负载/恒流源 https://bbs.38hot.net/forum.php?mod=viewthread&tid=71860
DIY高精度四双120A恒流源 https://bbs.38hot.net/forum.php?mod=viewthread&tid=69964
LEM高精度大电流传感器 https://bbs.38hot.net/forum.php?mod=viewthread&tid=67990
DIY 精密测量用1mA、10mA、100mA恒流源 https://bbs.38hot.net/forum.php?mod=viewthread&tid=17593
DIY大电流直流电流比较仪  https://bbs.38hot.net/forum.php?mod=viewthread&tid=11252
直流标准大电流   https://bbs.38hot.net/forum.php?mod=viewthread&tid=10230
直流微电流源 https://bbs.38hot.net/forum.php?mod=viewthread&tid=5670
超级微弱电流 https://bbs.38hot.net/forum.php?mod=viewthread&tid=851
做个分流器 https://bbs.38hot.net/forum.php?mod=viewthread&tid=241
标准电流 https://bbs.38hot.net/forum.php?mod=viewthread&tid=199
9、电源
DIY 1500W、600A高精度恒流电子负载 https://bbs.38hot.net/forum.php?mod=viewthread&tid=70999
100Ah、12V铁锂电池组及DIY 500A保护电路 https://bbs.38hot.net/forum.php?mod=viewthread&tid=12849
采用KIS-3R33S模块制作的恒压恒流电源 https://bbs.38hot.net/forum.php?mod=viewthread&tid=15883
Daiwa SS-330W开关电源的原理和改动 https://bbs.38hot.net/forum.php?mod=viewthread&tid=12083
HP6632B电源 https://bbs.38hot.net/forum.php?mod=viewthread&tid=633
几个电源的低频噪音的测试 https://bbs.38hot.net/forum.php?mod=viewthread&tid=195
10、温度
铂电阻Pt100与温度测试 https://bbs.38hot.net/forum.php?mod=viewthread&tid=7964
温度系数及测试方法 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1193
如何测试局部温差(热电法) https://bbs.38hot.net/forum.php?mod=viewthread&tid=133
11、其它
伯德图(Bode Plot)及其在运放稳定分析中的应用  https://bbs.38hot.net/forum.php?mod=viewthread&tid=78754
复合运放  https://bbs.38hot.net/forum.php?mod=viewthread&tid=73072
磁悬浮的种类  https://bbs.38hot.net/forum.php?mod=viewthread&tid=15726
三爪三同轴插头改二爪三同轴  https://bbs.38hot.net/forum.php?mod=viewthread&tid=11522
MSA338便携式频谱仪 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1216
论放大镜 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1181
本论坛图片的保存方法 https://bbs.38hot.net/forum.php?mod=viewthread&tid=773
标准电容 https://bbs.38hot.net/forum.php?mod=viewthread&tid=153
===================以下重复列出,按照发表的时间顺序,后发表的在前面===================
bg1grn's 4910维修案例 https://bbs.38hot.net/forum.php?mod=viewthread&tid=6851
精确测试标准电阻SR104的温度系数 https://bbs.38hot.net/forum.php?mod=viewthread&tid=1352
发表于 2009-7-19 10:17:56 | 显示全部楼层
这样学习起来方便多了,谢谢老大! [s:21]
发表于 2009-7-19 15:43:45 | 显示全部楼层
这样学习起来方便多了,谢谢老大!  [s:31]
发表于 2009-7-19 22:05:06 | 显示全部楼层
[s:30] 认真学习。
发表于 2009-7-20 18:31:20 | 显示全部楼层
认真读几遍。
发表于 2009-8-1 02:28:17 | 显示全部楼层
查找确实方便很多!谢谢老大!
发表于 2009-8-8 08:44:25 | 显示全部楼层
支持! 可以出书了.
回复 支持 0 反对 1
发表于 2009-8-10 10:38:15 | 显示全部楼层
Re:我的文集 lymex文集 记号
lymex文集 记号
发表于 2009-8-15 11:34:52 | 显示全部楼层
这样学习起来方便多了,谢谢老大!
发表于 2009-8-21 01:16:48 | 显示全部楼层
难得好资料,收藏了。
发表于 2009-9-3 01:23:54 | 显示全部楼层
发表于 2009-9-3 19:41:40 | 显示全部楼层
高!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2009-9-27 12:17:39 | 显示全部楼层
学习中!!!
发表于 2009-10-14 11:29:21 | 显示全部楼层
这样好.方便.谢谢LD!
发表于 2009-10-15 01:55:17 | 显示全部楼层
强烈支持!!学习中
发表于 2009-10-15 20:38:54 | 显示全部楼层
lymex老师能否把一些常见高位表电压基准部分的电路,PCB布局,元件选用做个比较和点评?
原来早有了,找到:
http://www.38hot.net/bbs/read.ph ... p;page=e&#a
发表于 2009-11-7 04:35:38 | 显示全部楼层
lymex文章太好
发表于 2009-11-7 08:03:24 | 显示全部楼层
强烈支持。
发表于 2010-2-26 09:01:56 | 显示全部楼层
好!这一定要收藏
发表于 2010-3-25 20:17:42 | 显示全部楼层
我打印 !!!!!!!!!!!!!!学习!!!
发表于 2010-8-9 04:53:12 | 显示全部楼层
谢谢老大
发表于 2010-8-26 17:25:24 | 显示全部楼层
OK。我知道了1
发表于 2010-9-8 07:05:57 | 显示全部楼层
好资料,收藏 [s:29]
发表于 2010-9-11 20:44:43 | 显示全部楼层
版主是中测院的吗?
发表于 2010-9-23 12:37:44 | 显示全部楼层
手持表那个难道不公开吗?
发表于 2010-9-25 11:47:44 | 显示全部楼层
院士文集, 收藏了
发表于 2010-10-31 17:11:47 | 显示全部楼层
书山有路
发表于 2010-12-1 10:10:11 | 显示全部楼层
lymex 老师:
直流微电流源 https://bbs.38hot.net/read.php?tid=5670
这篇文章要密码啊
发表于 2010-12-6 20:44:24 | 显示全部楼层
这样好.方便.谢谢LZ! [s:31][s:31][s:31]
发表于 2010-12-27 22:46:32 | 显示全部楼层
好东东
