楼主: pitaev
修了一堆Tek 2465
发表于 2018-5-4 01:07:36 38hot手机频道 | 显示全部楼层
技术贴,必须顶。。
发表于 2018-5-14 13:44:11 | 显示全部楼层
pitaev 发表于 2018-5-3 11:32
没钱收啦。 风扇不转很好办, 检查风扇是否断路。 加点润滑油或者换个风扇就好了。
高手!有没有2465的CPU板!我的2465存储模块的4块28P的集成电路座接触不良!我拆换的时候温度高了!板爆了
 楼主| 发表于 2018-5-14 20:17:56 38hot手机频道 | 显示全部楼层
没有啊 我也是自己修玩具
发表于 2018-5-14 22:04:36 38hot手机频道 | 显示全部楼层
技术贴
发表于 2018-5-21 16:15:57 | 显示全部楼层
Many thank your experience ! I have one 2465B , when power on , selftest and checking led flashing . Display have out forcus , and need to click to trigger to run. I checking U950 - Zamp have only signal in VG out, VZ out dont have any signal .
My U950 Burn out or other fail ? Thank so much !
 楼主| 发表于 2018-5-22 22:02:45 38hot手机频道 | 显示全部楼层
well, your descriptions are rather vague. So is it fussy before pressing the trig button? Or it is still fussy after doing so. There are alternative reason for a dead VZ. Hard to know before seen a picture of your screen.
发表于 2018-5-24 10:02:28 | 显示全部楼层
Hi Pitaev
Oscilloscope display blurry when power on when durring sefttest and after click to Trigger Button. Verything Blurry and intensity not working ( CRT intensity and Redout intensity )
I attach picture for description error ! I live in Yuenan so sorry for chinese language .
Thank you so much !
发表于 2018-5-25 10:27:26 38hot手机频道 | 显示全部楼层
记号一下吧,我 也正在修2465a
 楼主| 发表于 2018-5-31 22:17:48 38hot手机频道 | 显示全部楼层
It is funny you can find info in a Chinese forum from Vietnam. I guess you need to improve either English or Chinese a little bit more for easier communication. Pleas check the voltage and ripple level of your power supply. Particularly the 42 and 87v
发表于 2018-7-9 16:21:56 | 显示全部楼层
楼主好强大,技术好英文也很OK,顶楼主。
GMT+8, 2020-5-26 11:57 , Processed in 0.585603 second(s), 25 queries , Gzip On.
