查看: 470|回复: 2
吉时利2700的校准手册或者校准方法谁有的
发表于 2018-5-14 17:49:55 | 显示全部楼层 |阅读模式
吉时利2700的校准手册或者校准方法谁有的,2700和2000的校准方法好像不太一样,没找到门路,有知道的共享一下呗!
发表于 2018-5-14 18:18:03 | 显示全部楼层
朋友能否把2000的校准方法传一份给我,谢谢!邮箱已经站内信了
 楼主| 发表于 2018-5-16 19:13:19 | 显示全部楼层
已经解决了,2700的校准方法是1. Turn on the Model 2701 and allow it to warm up for at least two hours before performinga calibration procedure.
2. Start the calibration process as follows:
a. Access the calibration menu by pressing SHIFT then TEST, then display TEST:
CALIB using the up or down range key. Press ENTER.
b. Use the up or down range key to scroll through the available calibration menu
items until the unit displays RUN, then press ENTER.
c. At the prompt, enter the calibration code. (The default code is 002701.) Use the
left and right arrow keys to move among the digits; use the up range key to increment
numbers and press the down range key to specify alphabetic letters. Confirm
the code by pressing ENTER.
d. Choose N at the prompt to proceed without changing the code, then press ENTER.
3. Choose which of the calibration tests summarized in Table 2-2 you want to run at the
CAL: RUN prompt. Use the up and down range keys to scroll through the options;
select your choice by pressing ENTER.
总共是三层菜单,进去了按照它提示一个一个的来就行了。
GMT+8, 2018-9-19 16:08 , Processed in 0.790510 second(s), 27 queries , Gzip On.
